How to requests and questions Please post your requests and questions for How to Guides.
Timing
Old 10-10-2019 | 10:00 PM
That white balt's Avatar
Timing
How to get back into the right timing when chain slips/breaks without causing damage to the motor
Old 10-11-2019 | 08:46 AM
cw383's Avatar
Watch this video. Really good job they did. There is a shim over the crank gear, remove it with a pick or the corner of a razer (box cutter style) to reveal the timing dot. Dont forget to put in back on when you go to reassemble! You will have to remove valve cover, front cover, remove and reset ( or better yet replace ) tensioner and exhaust cam sprocket. Camshaft bolt and harmonic damper bolt are torque to yield so they will need replaced.
Old 10-11-2019 | 09:20 AM
jdbaugh1's Avatar
Not all Ecotecs have the shim. Mine does not. If your timing slipped or chain broke you definitely need to do the full timing chain kit and replace all guides. Setting the timing is easy, there is a dot on crank sprocket, "Exh." indicator on exhaust cam, and "Int." indicator on intake cam. The timing chain will have painted links that you align with these three components. I like to activate the tensioner after setting the timing because I don't want to risk skipping time of first start up.
Old 10-11-2019 | 11:06 AM
I just release the tensioner before I thread it in, always worked for me and no chance of it not actually being released.
Old 10-11-2019 | 11:31 AM
jdbaugh1's Avatar
I thought the problem with this was that the tensioner has different notches which act as slack adjusters that don't allow the tensioner to compress as much once it extends far enough to slide onto the next notch. I assumed this is why you aren't supposed to do that but don't know for sure.
I use a drumstick with a plastic tip to reach down and give the guide a whack so it activates after installing.
Old 10-11-2019 | 11:49 AM
Thousands of miles and no issues, even did other peoples cars that way too.
Old 10-11-2019 | 02:37 PM
jdbaugh1's Avatar
Only issue I would see is if you had a new chain that wasn't stretched. The lack of slack could cause excessive load on the tensioner against the chain which I could see causing accelerated wear on your tensioner plastic bearing material. Not necessarily something you would notice the side effects of. I still wouldn't recommend doing it that way if you can help it.
Old 10-11-2019 | 02:38 PM
Pretty sure powell recommends doing it that way. To each his own.
Old 10-11-2019 | 02:57 PM
jdbaugh1's Avatar
I lean on the side of caution as it's not hard to activate once installed. I don't think GM would have included a component feature that adds significant manufacturing cost if it had no benefit. Maybe it is a useless feature, but my thinking is why take the chance?
DeanSsspsh (08-31-2024)
Medida
05-11-2018 11:35 AM
Chris Dashiells
09-01-2014 07:31 PM
Drunkship
05-18-2013 01:06 PM
superrslow
07-17-2012 09:59 PM
06cobalt_ss
10-24-2009 12:59 AM
