How to requests and questions Please post your requests and questions for How to Guides.
Treadstpne block off plate
Old 01-07-2015 | 08:08 AM
09RallyTC's Avatar
Hey guys, right now I have the Tial BOV installed with factory bpv. I came across a brand new block off plate for a great deal and was wondering if there's a how to on installing it?
Old 01-07-2015 | 08:39 AM
blueLNFftw's Avatar
Remove old.
Replace new.
Why do you need a "how to"?
And its been out for a while...
Old 01-08-2015 | 10:35 AM
09RallyTC's Avatar
I purchased it off someone who didn't have a need for it, I knew they have been out just didn't want to spend the full price.
The reason I posted here was because I couldn't find a thread on it anywhere also,Never installed one before and was looking for info on "How to". Thanks for you info.
Old 01-08-2015 | 10:56 AM
blueLNFftw's Avatar
IS your car tuned for VTA?
Old 01-09-2015 | 11:15 AM
09RallyTC's Avatar
I'm pretty sure it is, when I bought it it had the zzp charge pipes and intercooler with maf relocate. With an aftermarket BOV. It was leaking and I replaced it with the Tial.
Old 01-09-2015 | 11:18 AM
blueLNFftw's Avatar
Does it spike rich between shifts?
Who tuned it?
Does it have the factory BPV in place still?
Old 01-09-2015 | 11:46 AM
user 72239's Avatar
you just replace your factory BPV with the Treadstone one. 3 10mm bolts.
Unit is on the turbo itself. its an tan looking thing with a nipple
Old 01-09-2015 | 05:35 PM
09CobaltSS1's Avatar
If the maf is already relocated to the cold side charge pipe, there shouldn't be an issue with simply installing a block off plate when used with a vta bov. Just be sure to get a vacuum source for the bov directly from the manifold and NOT the bpv solenoid (the line originally going to the bpv nipple).
Old 01-09-2015 | 05:41 PM
blueLNFftw's Avatar
How come?
Old 01-09-2015 | 05:44 PM
user 72239's Avatar
It doesn't work right.
It flutters really badly. I had to block off my lower CP vacuum port with a screw and then run the BOV straight to the Intake manifold
Old 01-09-2015 | 06:35 PM
Originally Posted by blueLNFftw
How come?
Yeah, like leemanfor said, it just doesn't work right.
The bpv solenoid is controlled to partially open and close at points in the tune that just doesn't jive with a bov. A bov is designed to work best with a true manifold vacuum source.
Old 01-10-2015 | 03:25 PM
blueLNFftw's Avatar
thank you
Old 01-11-2015 | 03:48 AM
09RallyTC's Avatar
Thanks guys.
05-28-2022 04:47 AM
01-12-2016 01:01 AM
ineedacobaltss
11-07-2015 03:25 PM
Trav3480
10-01-2015 09:17 PM
goaliemo
09-28-2015 02:37 PM
