HP Tuners HP Tuners are a Supporting Vendor of CobaltSS.net
contacts: HP Tuners
HP Tuners: Regular or Pro??
Old 08-19-2006 | 11:51 AM
automobiliben's Avatar
I was wondering which version of HP Tuners everyone went with. I would like to know if the Pro is worth the extra money, or is the regular version good enough. Thanks for any input.
Old 08-20-2006 | 09:58 AM
Anyone?
Old 08-20-2006 | 10:50 AM
M88ArRamadi's Avatar
I should have posted this earlier....I want to know the answer too.
Old 08-20-2006 | 02:44 PM
djt81185's Avatar
Pro without a doubt
Old 08-20-2006 | 02:46 PM
patathSS's Avatar
Go Pro. ITs worth it.
Old 08-20-2006 | 02:48 PM
Waylin22's Avatar
What is the difference in the 2 pat??
Old 08-20-2006 | 02:49 PM
Waylin22's Avatar
I want the pro version..but 700$ buys MOST of the mods on my **** list.
Old 08-20-2006 | 02:50 PM
patathSS's Avatar
Question MPVI Std and MPVI Pro (Enhanced IO) Interface Differences
We sell 2 hardware models with our VCM Suite package.
What does the MPVI Pro interface allow me to do?
With our Pro interface, you can use 0-5v signals from various sensors such as EGT, Wide Band, fuel pressure and others for sensor input in our scanner. You will have real time data from those sensors right next to your standard scan tool data such as TPS, RPM, MPH, etc.
Our MPVI Pro interface also has black box data logging built in. What this means is you are able to scan your vehicle without the use of a laptop using the interfaces record button. You can then take the interface into your home to transfer the log contents from the interface to the computer. If you have an MPVI Pro it will require no hardware modification. Also note that VCM Scanner comes with both interfaces regardless as it is part of our VCM Suite package.
Can I buy a wide band sensor and simply plug it in?
No. You need a wide band kit that supplies a 0-5v output. You will plug the output from your wide band controller into our interface.
How many external devices can I have?
We have provisions for 4 external devices that use a 0-5v output signal.
I am a current customer with VCM Suite but I want the new MPVI Pro interface, how do I buy it?
MPVI Pro (Enhanced I/O) Upgrade Process
Copied directly from HPTuners forum.
Old 08-20-2006 | 02:53 PM
patathSS's Avatar
Also HP Pro has outputs that can control functions. It could be used to run a boost bypass valve or other things.
Old 08-20-2006 | 03:37 PM
So this means....what?
Standard will only allow you to view and edit PCM
Pro will let you do standard things and connect other devices such as boost guage and AFR gauge and read them on HP Tuner software?
Old 08-20-2006 | 03:52 PM
patathSS's Avatar
Correct. You can still scan with the Reg edition but you cannot have any analog inputs, such as a wideband. Also, the black box data recording feature is nice because you don't always have to have a laptop with you.
Old 08-20-2006 | 06:48 PM
HOW LONG DOES THE the black box data recording feature last?
Old 08-20-2006 | 06:54 PM
SLOWBALT06's Avatar
how much is the pro version and how much is the regular
Old 08-20-2006 | 06:55 PM
499 and 649
Old 08-26-2009 | 01:10 PM
240b's Avatar
MPVI Pro is the way to go. Way more flexibility for tuning via wideband if you wanted.
I have one that's barely used with 6 of the 8 original credits left. Transfer of ownership is easy and fully endorsed by HP Tuners (they go above and beyond to make sure the transfer goes smooth). I hate to part with it after no really getting all I could out of it but I had to sell my car earlier this year. No use for it now. Let me know if you're interested.
Haily229
09-17-2015 07:18 AM
Highgross89
20
09-11-2015 03:24 PM
The Rookie24
08-27-2015 09:18 PM
The Rookie24
08-24-2015 10:37 AM
Quick Reply: HP Tuners: Regular or Pro??
