INTENSE Announces LSJ Supercharger Spacer Kit
This spacer plate is CNC waterjet cut for perfect fit and finish and raises your M62 supercharger by 1/2 inch. There are a couple of advantages to installing this spacer kit. The first is that it will allow you to tap a hole in the spacer to install water injection, nitrous nozzles, air temperature sensors, etc... and the second is that it will effectively reduce the belt size by aproximately one inch allowing you to take a lot of slack out of the stock belt.
$149.99
$149.99
$149.99
$149.99
thats awesome, No I'll consider water injection.
through the intake just doesn't make sense to me. it's better to cool hot air then the ambient temperature air outside the supercharger.
thanks guy's
thanks guy's
Good question, not sure why not, but I have to run it by Tim and Scott.
single in center and dual between 1-2 ad 3-4 would be great for single or dual nozzle water injection applications
still debating between twincharging or waterinjection/full exhaust
09-28-2015 12:51 PM
