INTENSE-Racing.com Intense Racing is a proud Supporting Vendor
INTENSE Stage 4 HELP!
Old 08-19-2006, 11:18 PM
  #51
M88ArRamadi's Avatar
Hey vandy0419---->> You ging back to INTENSE for them to check your car?? We have the EXACT same numbers, mods, and problems.
Edit: I'm going to buy HP Tuners if INTENSE walks me through the tuning, and helps me fix the problem
Old 08-19-2006, 11:22 PM
  #52
vandy0419's Avatar
I don't know, I think I'll just use my money to go in on HP Tuners and get someone's tune flashed on it that no one has had problems with.
Old 08-19-2006, 11:25 PM
  #53
I have the original GM flash and thought of doing that. I decided that I should learn how to tune.
Old 08-21-2006, 08:51 AM
  #54
vandy0419's Avatar
I'm going to ask around some people I know and see if they know of any differences between the RL and Cobalt flashes...
Old 08-21-2006, 11:04 AM
  #55
that sounds good.....I'm going to do the same for now
Old 08-21-2006, 11:29 AM
  #56
vandy0419's Avatar
Well talked with a few guys on the RL forums and it ends up INTENSE doesn't do much with the VE table and that is what everyone else is changing almost immediately.
Old 08-21-2006, 12:01 PM
  #57
06blackg85ss's Avatar
I was under the impression that the VE table only comes in to use if the maf fails....
Old 08-21-2006, 03:34 PM
  #58
I'm buying HPT tomorrow depending on scott or todd's response. WOW that crap is expensive. 650+shipping
Old 08-21-2006, 04:19 PM
  #59
vandy0419's Avatar
I'm fortunately going in on it with 3 other people so its less than $170 each
Old 08-22-2006, 09:42 AM
  #60
CobaltSS422's Avatar
is that for the Pro version?
Old 08-22-2006, 09:52 AM
  #61
vandy0419's Avatar
Yeah...there you can hook up a wideband and it will read it out on HP Tuners...
Old 09-01-2006, 01:45 AM
  #62
Alright INTENSE though I might be over-reving the sc and recommended me to down grade to a 2.6" or 2.7". SO.........I bought a 2.6" pulley and ......even worse than I thought ..... 14 psi!! I removed ALL parts of the stage 4 checked them and re-installed them. I, once again, ripped apart and re-installed the sc and by-pass valve.
Before the downgrade I COMPLETELY bypassed the by-pass valve. I went for a quick ride and my car **** it-self. Said something like "torque managment power reduced" I had NO POWER and shitty idle. I shut it off waited a minute and turned it back on. I was able to make it home. The car felt like it had Hella power UNTIL I went WOT.
Old 09-01-2006, 07:44 AM
  #63
djt81185's Avatar
Try running a compleely stock air box for one
pull s/c and clean all gasket mating surfaces
ensure no belt slip...check idler and pulley for dust
Run a manual bypass on s/c
if its hitting limp mode im betting its something to do with ur airbox
Dan
Old 09-01-2006, 11:52 AM
  #64
Dan
1. I have a completely stock airbox....I had to remove the air-box mod because I was getting the LEAN code when I first got the s-4.
2. I've removed, tore apart, cleaned, inspected, re-assembled, and installed the sc 3 times now.
3. No belt slip.....no squeaks or black dust (have GM S-2 belt)
4. Ran a manual boost by-pass ... little to no difference
05-28-2022 03:47 AM
DarrenGC
12-24-2021 01:55 PM
HEATON
10-16-2015 07:21 PM
nathan112i
09-30-2015 07:12 PM
grampss
09-27-2015 08:51 PM
Quick Reply: INTENSE Stage 4 HELP!
