The OFFICIAL Aeroforce Interceptor Gauge Problem Thread
#76
Originally Posted by sethallen
before the LCD screen wouldnt display information. Now it displays information, but it takes up to 10 seconds sometimes to refresh itself. Like when coasting, PSI is like -9. Well if you go WOT, it still says -9 for up to 10 seconds before updating to 12, 15 PSI etc. There is an option to change the data rate (how fast it updates) and i have it set to the fastest rate...
#77
planning on buying one from intense, hopefully it will work, im trying to see if they have any of the older editions, without the shift lights, beacuse those seem to be problem free.........
#78
Todd
#79
I just got mine from Intense last week and installed it on Sat. I love it except I also have the problem with the very slow refresh rate. I notice you guys are located in Columbia Station. I live like 5 minutes from you guys. Can I maybe stop by sometime and have you check it out and see what you guys think?
#82
Just filled all of our red gauge backorders today with more on the way, we sell these things faster than Aeroforce can stock us Kudos to Todd at Aeroforce for being very active in taking care of customer issues, they are the epitome of vendor's we like to deal with.
#85
360 L337 User
I called and ordered mine today, and intense said that todd was adding some precautionary thigs to the gauges and this shipment should have no problems. but I have an 05 so mine should be fine anyway.
#86
Originally Posted by forcefedjunkie
Be sure that the connector is seated all the way in the OBD2 port, and that none of the OBD2 port pins are pushed in, which is not that uncommon. We're sending you another anyway just to be sure. This has no relation to the 12v power issue.
Todd
Todd
Todd I read alot of your posts and am very impressed with your great customer service.
#88
to all who where asking if its safe to buy yet....
the answer is YES!
I did the testing on the gauges with the "fix" and so far its gone 3 weeks and NOT A SINGLE problum!
Todd and aeroforce has fixed the issue and this is such an awesome gauge that it doesnt make sence to NOT get one!
the answer is YES!
#90
Todd
#91
the answer is YES!
the answer is YES!
#92
1 Post
the datarate is set to 1, which is the fastest. I also tried it at the other settings, but same issue. I definetily do not regret getting this gauge. If there EVER is a problem, i know for a fact that Aeroforce will properly take care of you. They have EXCELLENT customer service. As you guys have read, I noticed the problem yesterday, and Todd has already put a new gauge in the mail. I will let everyone know. I am sure it is something simple, and I doubt every gauge will have the issue.
If you are considering buying the gauge...quit thinkin, and buy it! Well worth the money. Aeroforce definetily backs their products 100%
#93
I already did a search and this thread came up so here goes...does the Interceptor display A/F ratio? I was looking at the features list on Intense.com and was too retarded to figure it out. Does anyone have the right answer?
#95
The AEROFORCE Interceptor Scan Gauge does the following:
RPM
MPH
Intake Air Temperature pre intercooler
Intake Air Temperature post Intercooler *
Mass Air Flow Sensor Frequency *
Mass Air Flow Sensor (lb/min.)
Engine Coolant Temperature
Injector Pulse Width
Long Term Fuel Trim
Short Term Fuel Trim
O2 Sensor Voltage
Manifold Pressure in PSI (Boost pressure)
Supercharger Inlet Pressure *
Ignition Advance
Knock Retard *
Engine Run Time
Battery Voltage
Throttle Position Percentage
Engine Load
Instantaneous fuel economy
Horsepower
Analog input #1
Analog input #2
* Critical tuning parameters not found on most other scan tools for the Cobalt/Redline!
RPM
MPH
Long Term Fuel Trim
O2 Sensor Voltage
Ignition Advance
Knock Retard *
Engine Run Time
Battery Voltage
Engine Load
Horsepower
Analog input #1
Analog input #2
#96
Todd
Aeroforce
#98
Originally Posted by player_1
hey Todd
any Idea if they fixed the Issues with the LC-1?
Todd
Aeroforce
#99
thats good, I wanted to get a Wide band to go with my aeroforce gauge. and had wanded to use the LC-1 because it's supposed to be one of the highest resolution, and cheaper then buying other widebands with gauges.
