Ported Blowers?
Ported Blowers?
What kind of gains are we looking at here?
or any more information than what is listed on the site, I and many other members are interested.....
Porting a blower is the equivalent to porting an intake manifold of a turbocharged engine. You'll be able to make the same power at less boost or more power at same boost. If you add boost, you'll have even greater gains. If I were to guess, I'd say 15-20hp on stock boost setting of 12psi. Add 5 psi and you should see gains of 30-40hp and if you add a 2inch primary runner/3 inch collector header with a 3inch exhaust and a nice CAI you should see peak gains with that blower running at 17psi. Of course, this is with a tune. If this is not satisfying to you, port the head and put Tri-Cams in and you should be WAY over 300whp. Which is enough power to be classified in "ball-busting acceleration".
The M62 doesnt have a significant restriction in the outlet path of the blower. Ported or not, you can still only make as much boost as your rotors will support.
