JBP VORTEX Header group by????
#301
care to elberate... what material behind the header?
Last edited by Noir_Destruction; 02-11-2009 at 01:22 AM. Reason: Automerged Doublepost
#302
It makes it easier if you remove some of the firewall insulation. The package comes with header wrap so there wont be any heat issues if you do remove some of the black cloth/heat insulation...
#304
i was originally gonna buy the 3 inch cti dp with my vortex header, adn 2.5 exhaust, but i heard from a tuner that i would get more power from a 2.5 inch dp with this set up, and this guy is running with a 2.6 pulley and 60 injectors also
#306
For install you might want to remove the half-shaft to make it easier...if you you are doing it on your own...
#310
1) Guys, there is no header wrap included with the header as it is not needed.
2) There is no need to grind or cut anything anywhere.
3) There shouldn't be any need to remove the firewall insulation, it will fit right infront of it just fine.
#312
you must have a magical cobalt then
