JBP VORTEX Header group by????
Old 02-19-2009, 02:21 AM
  #426
tdipowered's Avatar
i want mine so bad hurry up canadian people!!! lol i guess its customs fault..international mail = fail
Old 02-19-2009, 03:01 AM
  #427
racehtecobalt's Avatar
rootbeer.......good luck installing it......hahaha ive done that bitch 3 times already.........big headach
Old 02-19-2009, 03:19 AM
  #428
RooTBeeR's Avatar
yeah, thats what iv been hearing haha
Old 02-19-2009, 09:47 AM
  #429
JBP
JBP's Avatar
Originally Posted by andrew97
question tho how many bolts and washers are supposed to come with it?
There should be 9 hex bolts and 9 washers with it. The lower center stud and nut are reused to make it easier to hang.
Old 02-19-2009, 02:40 PM
  #430
ajjaro's Avatar
i passed by alocal muffler shop today, they gave me an amazing price, their making me a 3 inch downpipe, installing my vortex header, with the downpipe and the magnflow high flow cat, exhaust... all for 385$ after tax canadian dollars
Old 02-19-2009, 09:11 PM
  #431
Rippin07's Avatar
Vortex header install
Okay, I recieved the header but my car is in storage and Raptors also got one, we just finished the install on his.
First, this is no joke, it is easy to put on and we did it with the car on the floor. 2.5hrs total time.
We installed this on his 07 Ion redline. Keep in mind that there is slightly more room on the Cobalt SS, and there is alot of clearance room for the header, nowhere near the firewall, no cutting or wrapping of primaries....GREAT JOB JBP!!
1. As per instructions, remove valve cover to gain extra clearance for hands. Remove the down pipe and exhaust manifold, pretty straight forward.
2. Do not remove the half shaft, not necessary, just slip the header in upside down (downpipe flange up first / head flange facing front of car) pivot it up on the passenger side and up it goes, once past the half shaft, rotate the header into its proper position for the flange to face up.
3. I highly recommend doing this, a little patience required. Keep the studs in the head, Only remove a stud if it interfers in installation, but reinstall after header is on!! Trim a 1/4" off the nut end of the# 2 primary lower stud (this one is directly behind a tube and is the only hard one to do)( almost impossible using the supplied cap bolts) We installed the header with 6 of the nine studs in place!! Then proceeded to install another stud and only used 2 cap bolts. Could have used all 9 but 2 were no good.
4. Install header gasket / NOTE.... before putting header up onto studs, tweak the A/C line that is in a C bend on the firewall, just slightly bend line to go up for clearance... BE CAREFUL!! and GENTLE!!
5. Install header onto studs and start threading on the old lock nuts/ now only put them on for a few threads and continue to install all the other header studs or supplied cap bolts.
6. When all the cap bolts/ studs are installed, tighten down from the center out, this will ensure the header stays even and flat on the mating surface.
7. Install your valve cover and be careful to make sure your ground strap on the driver side stays out from under the valve cover!! I have seen this more times than I want to count!!!
8. Install components, ( the PCV vent hose has two 13mm bolts, acutally one bolt one stud, only the bolt will but used on the passenger side of the valve cover, you will have to get a shorter 13mm for the other bracket as a header tube is too close to install the stud.) Install the O2 sensor and downpipe gaskets, tighten and start the vehicle check for leaks.... After the engine has warmed up, let it cool and go over the bolts to ensure they remained tight after the first heat cycle.
9. Enjoy your new header!!!!
Raptors says it has slightly better throttle response in the midrange and figures there is definetly more power, we will be putting the car on the dyno as soon as is possible. As for sound there is more growl under throttle and the pitch changed slightly but the car is still very quiet.
Keep in mind this car still retains the stock downpipe and catback. With the exhuast completely stock the car was putting just over 260whp down. We will dyno on the same dyno and log the same parameters, meaning IATs will be duplicated (IAT 2 ) when making the pulls. No tuning will take place to have a fair and accurate representation of the headers ability to make gains with just a bolt on application.
Also note that the header is installed on a modified car putting decent power to the ground so gains may not be representative to installation on a stock LSJ... Meaning it should make a bigger difference on a modded car. But gains are gains right..... I will see if we can get the car on the dyno early next week as Raptors is leaving town tomorrow.
Oh, it looks freakin sweet under the hood!!!!
I will put this disclaimer in here: I am an Auto tech and have done alot of performance work over the years, so I found this easy, however I feel anyone can do it, just take your time and take a break if needed. It will be easier after you take that break. Sorry for no pics as this install just seemed to happen out of the blue.
Old 02-19-2009, 09:13 PM
  #432
tdipowered's Avatar
coooool
Old 02-20-2009, 12:16 AM
  #433
RooTBeeR's Avatar
wow, that is a good deal man!
Originally Posted by Rippin07
Okay, I recieved the header but my car is in storage...
...Sorry for no pics as this install just seemed to happen out of the blue.
nice dude, thanks for the info.
Old 02-20-2009, 01:08 AM
  #434
ajjaro's Avatar
yup, the muffler is a weld-in, im hoping for 15whp
Old 02-20-2009, 11:45 AM
  #435
raptors_67's Avatar
Yeah I wasn't really planning on doing it either but we were slow at the shop so I figured I'd work on it while I helped the few customers that were in that day. The hardest part is just having patience to get all the bolts/studs in because a lot of the primaries are in the way. Has anyone asked for pictures of it installed? I can snap a few if anyone's interested.
Old 02-20-2009, 11:49 AM
  #436
Haz l33t wheelz.
ls1fbody's Avatar
please do, and use imagetree or this site to host it. Any and every angle you can get.
Old 02-20-2009, 03:39 PM
  #437
tdipowered's Avatar
ok i just got mine do i need to get header wrap?
Old 02-20-2009, 04:04 PM
  #438
raptors_67's Avatar
I will bring the car in the shop tonight and snap some pics.... ill even take some from underneath if you guys want. I didn't have to use any header wrap on my redline and there should be more clearance on the cobalts so I would say no. I really like the way this thing sounds. I was worried it would be loud and annoying. It's no louder than stock, a little different sound and has a bit of a mean growl too it.
Old 02-20-2009, 04:59 PM
  #439
tdipowered's Avatar
anyone?
Old 02-20-2009, 05:17 PM
  #440
bowtie32's Avatar
thanks for the info rippin07
Old 02-20-2009, 05:58 PM
  #441
raptors_67's Avatar
anyone?
maybe read the post right after your first one there?
Old 02-20-2009, 06:58 PM
  #442
Rippin07's Avatar
No header wrap is needed, there is plenty of clearance.
Old 02-20-2009, 09:40 PM
  #443
Noir_Destruction's Avatar
got mine today and the box was all smashed and trashed despite the fragile sticker... gasket was folded almost completely in half and only got 1 bolt and 1 washer so i e-mailed jbp and they said they'd send new ones out for me asap... AWESOME SERVICE!! cause i know it wasn't there fault!!!
Old 02-20-2009, 09:49 PM
  #444
ssyellowss's Avatar
mine was a nice neat box from ups, then i opened it and it was a completely trashed box that the header was in. gaskets ok but i figured it would have came with studs for the downpipe?
Old 02-20-2009, 10:31 PM
  #445
RooTBeeR's Avatar
install pics or ban lol
Old 02-20-2009, 11:29 PM
  #446
JBP
JBP's Avatar
Thanks for the +'ve comments... This was a real successful GB and thanks for all of those who participated. This officially ends the GB! (in 30 mins)
Old 02-21-2009, 12:52 AM
  #447
Cefaln452's Avatar
**** 51 mins late... next time
Old 02-21-2009, 02:37 AM
  #448
ajjaro's Avatar
so the whole steup is on including the header, the car si definetly more powerful, but my fuel economy went down drastically and my new magnaflow high flow cat sounds like my stock cat when it was busted? it buzzes under any acceleration, is that how a high flow cat is supposed to sound like?
Old 02-21-2009, 02:43 AM
  #449
bowtie32's Avatar
hey jbp i sent the money order on tuesday the17. so im still good right?
Old 02-21-2009, 02:58 AM
  #450
RooTBeeR's Avatar
...your millage went down cuz you flooring it more now
Quick Reply: JBP VORTEX Header group by????
