Mid Central NE, KS, IA, MO, and IL
Kc Peoples!
Old 03-08-2008, 02:30 PM
  #851
jeremie's Avatar
its nothing to worry about as long as it stops leaking and your clutch pedal isnt spongy or anything. if it feels good and stops leaking, you're good to go.
Old 03-08-2008, 02:34 PM
  #852
boostnss's Avatar
ok my clutch pedal is stiff as **** how lond was it before yours stoped leaking?
Old 03-08-2008, 03:02 PM
  #853
Rent me! per hour
Area47's Avatar
1:05
no package
Old 03-08-2008, 04:47 PM
  #854
jeremie's Avatar
well heres how my ordeal went.
put it in, bled it, test drove it. all good. topped off the fluid and went home. on the way the pedal got spongy when i was going to down shift. so while i was on the highway i just pumped the clutch every once in a while. (i live 25 miles from my work) so i get home and pump it for id say 10 minutes. check under it and fluid is dripping. so im like ****, did i tighten the bleeder?? well i let it sit over night and got in it saturday afternoon and drove it to my parents. and it was fine.
Old 03-08-2008, 05:20 PM
  #855
philipino guy's Avatar
Originally Posted by jeremie
ok.
mike, cable can align your car.
bryan, i cant do it to day my dad needs my help with a lot of ****
conn, what color fluid is the tranny leaking? is it gear lube or hydraulic fluid? after i did my clutch the actuator leaked for a while but then it was fine, it was like it bled itself out it was fucked up.
matt,....you suck.
thanks guys i ended up taking it too cable. boy does it look sexy all lowered!
Old 03-08-2008, 07:55 PM
  #856
M-Dub's Avatar
I will hopefully have my wideband and springs by the end of the month!
Old 03-08-2008, 10:16 PM
  #857
boostnss's Avatar
well damn i have had mine in for four days now everything seems fine but i idk it's coming from where that black looking bar goes in the tranny don't know what that is called.
Old 03-08-2008, 10:33 PM
  #858
jeremie's Avatar
the axle extension tube? on the passanger side?
Old 03-08-2008, 10:34 PM
  #859
boostnss's Avatar
yea it goes from the tranny to the passenger side
Old 03-08-2008, 10:51 PM
  #860
jeremie's Avatar
that may actually be trans fluid then. they may not have poped that shaft in all the way or the seal may be damaged
Old 03-09-2008, 11:37 AM
  #861
boostnss's Avatar
yea it's leaking pretty bad and it smells like trans fluid how do i go about getting a new seal?
Old 03-09-2008, 11:50 AM
  #862
jeremie's Avatar
probably have to get one from a dealership
Old 03-09-2008, 11:51 AM
  #863
boostnss's Avatar
do u know what the seal is called?
Old 03-09-2008, 02:05 PM
  #864
jeremie's Avatar
should just be called a passanger side axle seal.
Old 03-09-2008, 03:35 PM
  #865
Firebirdhorn's Avatar
Jeremie, how much does it cost to get an alignment at cable?
Old 03-09-2008, 04:39 PM
  #866
jeremie's Avatar
i honestly dont know
Old 03-09-2008, 05:04 PM
  #867
boostnss's Avatar
are those hard to change out like do you have to pull the tranny out agian? thanks for all the help btw
Old 03-09-2008, 05:30 PM
  #868
jeremie's Avatar
the easiest way would be to take the wheel off, undo the lower ball joint and pop it out of the knuckle. theres 3 15's that hold a bracket on the block, take those out and pull the extension tube out. then remove the old seal and pop the new one in.
Old 03-09-2008, 05:33 PM
  #869
M-Dub's Avatar
Well got back from the autoshow..... the new Cobalt is nice, the seats are pretty keww, and the brakes are nice... MOTOR is very cramped so no big turbo conversions.... But all in all it looks like they changed the stuff that needed to be changed!
All in all I can see myself driving a 4dr SS/TC in that slate grey metallic color!
Old 03-09-2008, 05:45 PM
  #870
jeremie's Avatar
did you press the clutch??
Old 03-09-2008, 05:59 PM
  #871
M-Dub's Avatar
Yeah.... it felt better than mine!
Old 03-09-2008, 08:50 PM
  #872
jeremie's Avatar
  #873
boostnss's Avatar
ok i think im going to try and get it covered under warrenty. matt if i can't get it fixed before this weekend i don't think im coming yup next weekend eather btw i have all the stuff you need to do the install
Old 03-09-2008, 08:51 PM
  #874
M-Dub's Avatar
I gotta' say that the SRT-4 and the MS3 were far better feelin'.... but I'm sure I'll get more for my car at a Chebby dealer.... I think my buddy Casey wants an HHR SS (which we are going to test drive one tomorrow)
Old 03-09-2008, 09:06 PM
  #875
slownlow's Avatar
saw in the paper today a hhr ss for 19900 sticker for about 24k i think. i should of got one of those
Quick Reply: Kc Peoples!
