Mid Central NE, KS, IA, MO, and IL
Kc Peoples!
Old 03-20-2008, 09:48 PM
  #1126
wallas06SS's Avatar
Originally Posted by boostnss
so i did some pulls earlyer today and i was getting crazy amounts of knock and i hit 13.0 afr
wowzers!!!
Old 03-20-2008, 11:30 PM
  #1127
boostnss's Avatar
yea but im running meth so i should be ok other then losing power
Old 03-20-2008, 11:41 PM
  #1128
wallas06SS's Avatar
I don't have a wideband so I don't know what mine is. But i'm guessing it's not good based on my dyno sheet.
Old 03-20-2008, 11:52 PM
  #1129
boostnss's Avatar
i love my wideband the best mod i have done yet. shawn is a nice guy but his tunes aren't the greatest bryan will get some power out of your car his tune is in my car right now but with the weather changing it's starting to act up so i hope he will tune my car pretty aggressive this time around
Old 03-21-2008, 12:42 AM
  #1130
wallas06SS's Avatar
I probably need to pick a wideband up but I keep putting it off for other mods. I felt a nice difference with shawns tune so I can't wait till Bryan tunes it to unleash the power. I would like an agressive tune but not too agressive because it's my daily driver.
Old 03-21-2008, 06:10 AM
  #1131
M-Dub's Avatar
He won't make it that aggressive.... he doesn't want a popped motor under his belt!
Jeremie and I get more aggressive tunes... well because for me I'm only like 5 minutes away from him! Not to much to get to his house or mine for that matter!
He's good he knows what the car can handle and what it can't... so you'll get more power and be more reliable than Shawns tunes!
Old 03-21-2008, 10:23 AM
  #1132
wallas06SS's Avatar
Can my car be tuned just as good without a wideband? Or do I need that to get in to the nitty gritty and get the full potential out of my car?
Old 03-21-2008, 10:27 AM
  #1133
boostnss's Avatar
it would help alot, you can put it one the dyno to get a afr right.
Old 03-21-2008, 10:34 AM
  #1134
wallas06SS's Avatar
I might have to get one. Do you have an interceptor on your also? Do I have to get a new downpipe with a bung on it or can I use my factory downpipe?
Old 03-21-2008, 10:41 AM
  #1135
Rent me! per hour
Area47's Avatar
conn. you control what the car does in terms of power. i told you that weather changes play hell with wot fueling.
fuel control > power enrich > pe
set this to 1.290 across the board and work it from there. this is your wide open fueling table.
Old 03-21-2008, 12:42 PM
  #1136
wallas06SS's Avatar
Is this the wideband that you guys ar using?
http://cgi.ebay.com/ebaymotors/AUTOM...spagenameZWDVW
Old 03-21-2008, 12:46 PM
  #1137
Rent me! per hour
Area47's Avatar
im running the innovate db series with the lc1 controller.
apparently a smurf exploded inside of my intake manifold.
Old 03-21-2008, 01:15 PM
  #1138
boostnss's Avatar
i know you said that weather with play hell with the fueling i just thought it was funny to hit 13.0 afr i wasn't tring to bitch about your tune i love the tune and i was expecting that to happen. the only reason i want you to tune me aggressive is because i start index racing in 2 weeks im in the 13sec bracket and i can't learn to tune in 2 week. i want a tune that i put in the car when i get to the track race the car then put a base tune back in the car and drive home that what im looking i don't know if that is somthing you will do or not but that what i would like. im sorry if i sounded like i was bitching i wasn't tring too you are the only one i really want tuning my car, i bought hp mostly to do logs not to tune maybe one of these years learn to tune too.
i have a aem it's about 250-300. or get what bryan has
hey if my 2.7 some how got put on the car(i didn't do it) would i need to change the tune completly of just the fueling part? i don't want any smurfs in my in my car yet. did anything really bad happen to your car or is it an easy fix?
Old 03-21-2008, 01:22 PM
  #1139
Rent me! per hour
Area47's Avatar
windshield washer fluid = exploding smurfs
set your pe at 1.300 and work from there. it may or may not freak out at 6200 rpms and dump fuel.
Old 03-21-2008, 01:30 PM
  #1140
boostnss's Avatar
ok i set it at 1.290 just got back from doing a couple of pulls afr was 12.4-12.6 but im still getting knock threw the whole pull it stats off at 6 counts then when i hit 5000rpms it's down to o.4 and my iat2 got to 111.
Old 03-21-2008, 01:39 PM
  #1141
Rent me! per hour
Area47's Avatar
richen the pe up. let it learn for a couple days, then do it again.
Old 03-21-2008, 01:42 PM
  #1142
boostnss's Avatar
ok. so no time to help me tune tomorrow?
Old 03-21-2008, 01:51 PM
  #1143
Rent me! per hour
Area47's Avatar
dunno yet. i haben't gotten a call about if i need to cry and drink beer
Old 03-21-2008, 01:57 PM
  #1144
boostnss's Avatar
lol yea well if need be i will have a beer with you. i hope nothing to bad happened i want to see you hit that 300 mark. thanks for help so far i still need that race tune somthing with some more timing im only hitting like 18-19 degress of timing but that could be because of knock.
Old 03-21-2008, 02:35 PM
  #1145
M-Dub's Avatar
I bet I have exploded smurf in mine as well.... Bryan I just ordered my db series Innovate LC-1 wideband kit with bung!
And after this weekend I'll get my springs too! And then I will be done and set... and prolly end up buying the HPT stuff once I move away!
I hope to still be here to witness the 300hp mark.....
Old 03-21-2008, 05:56 PM
  #1146
wallas06SS's Avatar
Where did you get your wideband Matt?
Old 03-21-2008, 06:03 PM
  #1147
boostnss's Avatar
i like that 1.290 across the board the car pulls much harder in the higher rpms. any word on your car bryan?
Old 03-21-2008, 06:04 PM
  #1148
Rent me! per hour
Area47's Avatar
car will be fine. come on up to kc.
Old 03-21-2008, 06:10 PM
  #1149
boostnss's Avatar
sweet i think kritter wants to come up to will you have time to tune him?
Old 03-21-2008, 06:12 PM
  #1150
Rent me! per hour
Area47's Avatar
i should
Quick Reply: Kc Peoples!
