Kc Peoples!
#1128
#1129
i love my wideband the best mod i have done yet. shawn is a nice guy but his tunes aren't the greatest bryan will get some power out of your car his tune is in my car right now but with the weather changing it's starting to act up so i hope he will tune my car pretty aggressive this time around
#1130
#1131
He won't make it that aggressive.... he doesn't want a popped motor under his belt!
Jeremie and I get more aggressive tunes... well because for me I'm only like 5 minutes away from him! Not to much to get to his house or mine for that matter!
He's good he knows what the car can handle and what it can't... so you'll get more power and be more reliable than Shawns tunes!
#1134
#1135
Rent me! per hour
conn. you control what the car does in terms of power. i told you that weather changes play hell with wot fueling.
fuel control > power enrich > pe
set this to 1.290 across the board and work it from there. this is your wide open fueling table.
#1136
Is this the wideband that you guys ar using?
http://cgi.ebay.com/ebaymotors/AUTOM...spagenameZWDVW
#1138
hey if my 2.7 some how got put on the car(i didn't do it) would i need to change the tune completly of just the fueling part? i don't want any smurfs in my in my car yet. did anything really bad happen to your car or is it an easy fix?
#1140
ok i set it at 1.290 just got back from doing a couple of pulls afr was 12.4-12.6 but im still getting knock threw the whole pull it stats off at 6 counts then when i hit 5000rpms it's down to o.4 and my iat2 got to 111.
#1144
lol yea well if need be i will have a beer with you. i hope nothing to bad happened i want to see you hit that 300 mark. thanks for help so far i still need that race tune somthing with some more timing im only hitting like 18-19 degress of timing but that could be because of knock.
#1145
I bet I have exploded smurf in mine as well.... Bryan I just ordered my db series Innovate LC-1 wideband kit with bung!
And after this weekend I'll get my springs too! And then I will be done and set... and prolly end up buying the HPT stuff once I move away!
I hope to still be here to witness the 300hp mark.....
#1146
