Mid Central NE, KS, IA, MO, and IL
Kc Peoples!
Old 06-16-2008, 11:30 PM
  #2326
hoffa's Avatar
he does have a thing for that
Old 06-17-2008, 10:27 AM
  #2327
Rent me! per hour
Area47's Avatar
feels good on me *****
Old 06-17-2008, 12:36 PM
  #2328
M-Dub's Avatar
"On the....HOLE!"
ya ya y aya ya..... I keep getting picked on up here.... and then they get mad!
Old 06-17-2008, 12:43 PM
  #2329
Rent me! per hour
Area47's Avatar
hehehehehehhe
i think there is a car show this weekend
Old 06-17-2008, 12:51 PM
  #2330
M-Dub's Avatar
O RLY? Oh, yeah I'm 1300 miles away now!
Old 06-17-2008, 12:56 PM
  #2331
Rent me! per hour
Area47's Avatar
better get to drivin
Old 06-17-2008, 06:59 PM
  #2332
isfun07's Avatar
how do you get boost control
Old 06-18-2008, 10:44 AM
  #2333
boostnss's Avatar
so bryan i don't know if i will be up saturday i was giving a friend a ride in the car and it had a really bad miss at 5000rpms in 2nd. i kind of ran a compression test but i don't think it was right #4 was 155 then we did it again and it poped and went to 170 then we did it again and it was 160. do you have any ideas? i don't know how to do a leak down.
Old 06-18-2008, 10:50 AM
  #2334
Rent me! per hour
Area47's Avatar
same compression test gauge?
if so. do a test cold. test the cylinders three times. average them. then do a math equation to get the percentage difference between them all. jeremie would know the service limit. i don't, im just a monkey with a laptop.
isfun. through me
Old 06-18-2008, 10:54 AM
  #2335
boostnss's Avatar
yea it was the same gauge. but it was an old one that was in the back of someones car im going to use mine tonight. it's not smoking or running bad (yet) can it miss and still be ok?
Old 06-18-2008, 10:59 AM
  #2336
Rent me! per hour
Area47's Avatar
it's not the magical rpm number. so you might be fine.
has your car ever hiccuped hard at "7k" rpms?
when the car is cold. pull the dip stick. feel for air comming out. no air, you're fine. pull the oil cap. excessive air comming out? blue smoke? nope? you're fine.
Old 06-18-2008, 11:10 AM
  #2337
boostnss's Avatar
no i was at 5 to 6000 rpms this was the frist time it has ever happend i will do what you said and let you know how it turns out.
ok no air from dip stick.theres air coming out from the oil fill but i don't know whats excessive.
Old 06-18-2008, 05:18 PM
  #2338
jeremie's Avatar
how do your plugs look? is there any black crap on the porcelin of the plug? if your cylinders are hitting 150 psi you're probably ok there.
Old 06-18-2008, 05:22 PM
  #2339
Rent me! per hour
Area47's Avatar
jeremie. kcir. tonight. be there. ignore what your woman says.
Old 06-18-2008, 06:47 PM
  #2340
jeremie's Avatar
cant make it. plus i already left independence and do not want to go back
Parker is running his vette, Rich will run his mustang, stangklenr will run his camaro..
some other guys are going. i want to run but i has wheel hop issues.
Old 06-18-2008, 06:55 PM
  #2341
Rent me! per hour
Area47's Avatar
god you suck so hard.
Old 06-18-2008, 08:32 PM
  #2342
jeremie's Avatar
i know
Old 06-19-2008, 10:13 AM
  #2343
boostnss's Avatar
plugs look fine. so i did another pull and it was fine to 7000rpm's and i was thinking about it if i hit the rev limiter would it cut fuel there for make act like it missed. if that was the case im going to have someone kick me in the ball for being suce a bumbass.
Old 06-19-2008, 10:38 AM
  #2344
Rent me! per hour
Area47's Avatar
bumbass
13.52@108
left the laptop at home. daily driver mode
Old 06-19-2008, 10:52 AM
  #2345
hoffa's Avatar
Originally Posted by Area47
bumbass
13.52@108
i was going to say
shouldn't you be running a wee better than that?
Old 06-19-2008, 10:54 AM
  #2346
Rent me! per hour
Area47's Avatar
2500da last night. humid. trying not to break something. nope, not really
Old 06-19-2008, 11:09 AM
  #2347
hoffa's Avatar
its humid down there??? noooooo waaai!
guys get any flooding problems down there?
giggled
Old 06-19-2008, 01:06 PM
  #2348
boostnss's Avatar
bumbass
13.52@108
can you make my car do that can i come up kind of early cuzz theres midnight drags this saturday and i kind of want to run the car after you make it happy so i will need to leave kc around 6, 7 at the latest.
Old 06-19-2008, 01:17 PM
  #2349
Rent me! per hour
Area47's Avatar
yep, thats fine d00d. my daily driver mode is still on the 2.7
11.5 afr and 20 degree's total timing. the car has no ***** down low at the track. i pick up close to 25 mph on the back half
hoff. no flooding here
Old 06-19-2008, 01:21 PM
  #2350
boostnss's Avatar
damn man thats crazy the tune i have right now has 23*of timming and when i went down the track i had a 12.0 tho 12.2 afr maybe that 109 is killing me hell i don't no.
Quick Reply: Kc Peoples!
