Mid Central NE, KS, IA, MO, and IL
Midwest Ecotec: Discussion
Old 02-16-2010 | 06:10 PM
  #476
Spanky's Monkey's Avatar
quincy's new baby thread
check it out
Old 02-16-2010 | 08:47 PM
  #477
rmpro1's Avatar
Originally Posted by mkriebs
Yeah, you should be able to do the PCV yourself... not sure how mechnaically inclined you are though. And, if the leakdown test failed, then its prolly the rings. I would still pull the PCV out and test it. Won't hurt, and could save you a bunch of money.
Also, don't take it back to the dealer to get the motor done. We could rebuild that sucker with fully forged internals for less that $5k.
yeah i know. i guess im going to get it back probably tomorrow or somthing so ill probably still come to the meeting.. i just cant drive it hard.. just until we decide what we are going to do.
Old 02-16-2010 | 09:52 PM
  #478
mkriebs's Avatar
What other symptoms do you have, besides the oil pushing out of the dipstick? Any oil consumption, any hesitation, smoking tailpipe? You may have mentioned it, but i don't wanna look through the thread for it.
Old 02-17-2010 | 12:26 AM
  #479
rmpro1's Avatar
well my car smokes white smoke when i get on it.. and in idle it misfires.. when i go down into first gear itll rev up and stay high about 2000 then go to about 900 rpm in about a half minute. Also when i first noticed the oil spit out of the dipstick i noticed that the muffler i had on the car was blown out thus perhaps causing blockage of the exhaust.
Old 02-17-2010 | 12:35 AM
  #480
BartSS's Avatar
Isn't white smoke mean coolant? That's no bueno
Old 02-17-2010 | 12:51 AM
  #481
Boosted_Cobalt09's Avatar
is it pissing water too? that would mean headgasket for sure. get all the cylinder leak down tests and compression test readings. i wanna know individual readings.
Originally Posted by Spanky's Monkey
CONGRATS!
Matt, I could pick you up too, on my way from WERKS to hooters... just taking you back home that might be the issue.
**** if you take 59 to hooters im maybe a 5 minute detour wanna pick me up and ill go to werks with you too?
Originally Posted by 06ss supercharged
i can pick you up bro its on my way there, and that way i wont get lost. LOL
you can drive me home so that problem is solved.
thanks guys for willing to help me out. i need to get this stuff on the car done.
Old 02-17-2010 | 12:54 AM
  #482
mkriebs's Avatar
Matt, I will be coming from werks to hooters. Unless you have that day off??
Well, what I don't understand is, how do you know what color your exhaust is when you get on it? Coming from other people, unless they are mechanically inclined, is a no no. If its cold out, again no no. If you got gas with ethanol in it, yet another no no.
If it was a head gasket, then you would get white smoke all the time, not just at WOT. Same with a warped head and a cracked block (even more so, though). Rings do not cause white smoke.
There are just too many variables here to diagnose ONE thing. The leakdown test is probably the most condemning, but I would definitely be hesitant to spend $5k on an engine. Ask for the paperwork with the leakdown results.
I mean, the logic is not behind a bad ring. Bad ring means the pressure on the bottom of the cylinder would be lower, due to it not holding the oil back. The dipstick is puking oil, or popping out, that means there is too MUCH pressure. Whether that be a stuck PCV valve, or too much oil (surely you have checked the oil level?????? please?????).
So, 1+1 is not equalling 2 here man.
Old 02-17-2010 | 12:56 AM
  #483
rmpro1's Avatar
the dealer ship said the compression test was
220 1
220 2
220 3
220 4
then the leak down test i guess cylinder 4 went to 60
Old 02-17-2010 | 12:57 AM
  #484
oh yeah nvm lol. i have to work so just grab me on the way if thats ok.
Old 02-17-2010 | 12:59 AM
  #485
rmpro1's Avatar
Yeah oil is full. top line of the dip stick. it goes down every time the dipstick pops out so i put more in sometimes lately.
Old 02-17-2010 | 01:01 AM
  #486
mkriebs's Avatar
Thats cool.
Old 02-17-2010 | 01:05 AM
  #487
hey not to give you **** but try a different dealer or ask them for a specific reading. theres no way in hell every single cylinder is going to read 220 exactly. their should be a little bit of movment. 220 221 220 224 as an example. ask them for exact readings on the leak down test.
Old 02-17-2010 | 01:07 AM
  #488
mkriebs's Avatar
rmpro1:
I really think the dealer is ******* with you, or some info is being skewed somewhere along the line. Compression tests are NEVER the same number, not even from the factory, brand new. There should be a ballpark range. With your mileage on the car (assuming more than 0 miles, right? Lol), your rings would be seated into the cylinder walls. Now, no ring will seat exactly the same, causing the difference in the compression test results. Typical results would be (for example, and example only) 217,220,221,219. Something like that, not 220 across the board.
Now, maybe the tech was rounding, generalizing, or whatever (which is a horrible idea, unless you are talking to a clueless teenage girl about it).
I will send you a PM regarding some solutions, sound good? I really think the dealer might be trying to **** you with a $5k bill.
Old 02-17-2010 | 01:11 AM
  #489
thanks for all the ride support guys!!!!! your all awesome lol. matts going to scoop me up on the way to hooters since we wont be far from me.....now who wants to take me home?
Old 02-17-2010 | 01:14 AM
  #490
mkriebs's Avatar
If worse comes to worse I can take ya home, but I figure if someone is running down that way, I will just shoot out on 90. Come to think of it, by the time were done, the interstate is gonna be all clear, so no traffic so it might actually save me time to go back down to 88.
Old 02-17-2010 | 01:24 AM
  #491
BartSS's Avatar
I can give you a ride home possibly
Old 02-17-2010 | 01:27 AM
  #492
mkriebs's Avatar
Bart, he wants to go to HIS home, not your home for you to have our way with him, lol!
Old 02-17-2010 | 01:37 AM
  #493
anyways my lady bought me a turbo timer and im offically 21!
Old 02-17-2010 | 01:40 AM
  #494
mkriebs's Avatar
Woo!!! Were gonna have to tap a keg of rootbeer matt! Since I will be driving home, i DEFINITELY won't be drinking... Not even one, since it makes me profoundly tired.
Old 02-17-2010 | 02:02 AM
  #495
lol me and you can be the sober ones since i dont drink lol. im such a lame ass
Old 02-17-2010 | 02:04 AM
  #496
YzRider452's Avatar
Man im glad i have an awesome girlfriend. DRINKS ALL NIGHT!!!!!!!
Old 02-17-2010 | 02:49 AM
  #497
BartSS's Avatar
Lol. You're still a communist **** hahaha
Old 02-17-2010 | 03:19 AM
  #498
mkriebs's Avatar
And your still polish...
Old 02-17-2010 | 04:10 AM
  #499
BartSS's Avatar
This is true
Old 02-17-2010 | 08:09 AM
  #500
bart its ok im polish too!
Quick Reply: Midwest Ecotec: Discussion
