Louisville Area Cobalts!
#4807
is there smoke at your house? fort knox is on fire and there is smoke everywhere on post. i could smell it at my house this morning. but its gotten a lot worse since ive been at work.
#4811
Yep juet neef to vaccum bleed agaain and adjust my zzp clutch rod to whwt feels righth and thn tune.. hey joe you can get a clutch from kentucky clutch for cheap,I,got a 8 puck that'll hold 700ft lbs of tq for 95$ just the friction disc.... so complete clutch kit I say 300-350
#4820
james- good luck finding a transmission any where near here. im pretty sure we know where most of the turbo'd balts are around here and they are all in working order. well...except yours. like i said, i know a guy that does a really good job at rebuilding trans. but if you said yours blew a hole in the side of it then that wouldn't work.
this is going to be long...but you need to read it.
i called kentucky clutch today and asked them about getting a clutch for my car. they said the only kit they had was an 8 puck style disc (assuming this is the one you got) but it only comes with the stock pressure plate. so i proceed to ask them how much just the disc is and i will re use my pressure plate. they said they didn't reccomend that i do that. they said the clutches on our cars are self adjusting and there isn't really much of a way to change them back once they have adjusted. so, my pressure plate has already adjusted to my worn out disc and putting just a new disc in there will either blow your slave cylinder or make it to where the clutch won't engage. i don't remember his exact wording, but basically he told me that if im going to replace my clutch. its better to just do it all at once otherwise im gonna **** some **** up. he told me that a dealership came in and had them put in a clutch in a cobalt and they only put the disc in because thats all the dealership wanted. well...the cobalt ended up coming back and they had to replace some other **** on it.
what im getting at here is, could this possibly be the reason for the demise of your transmission?
#4821
No my tranny went out either because of torque output or gm stupid ass trying to force my 3rd gear or it was just fucked up when I bought it... which I'm leaning to #3. I would also replace the slave /throwout bearing, clutch. Friction disc and the pressure plate. Ide get some fine grit sand paper and clean that flywheeel up if it has a lot of heat take it off and get it cleaned up.
