Louisville Area Cobalts!
#6094
i was playing with a yellow balt on gene snyder on the way home today. i believe he said he was a 2.4 and i saw he had oldham plates. i wasnt able to pull away from him. my clutch was slipping a bit.
#6097
So I'm having my first major problem with my ss and I think its time to take it to the dealer. What's everybody's dealer of choice for warranty work in the louisville area?
I guess I'll post the problem to in case anybody has any input, its a 2007 ss/sc
My car used to burn oil somewhat bad, enough to where it was easily visible. compression was 180,210,210,180 with oil being in cylinders 1 and 4. the problem slowed and there is no longer visible smoke, but if you pull the plugs (which get fouled a lot) there is oil in the cylinders. fast forward a couple months compression numbers get worse. on a hot test the numbers are more like 150,180,175,160 and oil occasionally appears in any of the cylinders, and is always in cylinder 1. car just doesn't feel like it should. I know theres a problem here, but am worried that the dealer will not recognize that since the car would seem to be driving fine to somebody that had never driven one before.
