Mid East MI, IN, OH, KY, WV, and VA
Magnuson/Eaton TVS 1900
Old 03-02-2012 | 03:32 PM
thuston10's Avatar
Question Magnuson/Eaton TVS 1900
I live in the Cincinnati area. Where Can I buy a TVS 1900 supercharger?
Old 03-02-2012 | 03:45 PM
zrated89's Avatar
a direct fit no where. modifications are needed to run that blower. I wouldnt waste your time man you could never really use the blower to its potential unless u had an ass ton of stuff done to your car
Old 03-02-2012 | 05:04 PM
thuston10's Avatar
My modes are:
2.8 pulley, custom HKS 272 cams, diamond 10:1 pitons, ti retainers, supertech 78lbs dual coil valve springs, intense/zzp hup n 60lb/hr injectors, throtle boby spacers, ARP head studs, wallbro 2551ph feul pump, vibrant header, full vibrant 3" exaust, ottp fuel return system, gmpp neutral balance shafts, cosmtic head gasket and water meth injection.
Old 03-02-2012 | 05:13 PM
zrated89's Avatar
with the higher compression you may be able to benefit as well as with cams. pm euthansia im sure he can point u in the right direction
SmitBag
09-07-2016 09:05 AM
Shanman
10-02-2015 10:01 PM
SSLOW06
10-01-2015 08:21 PM
RedLined
09-09-2015 10:11 PM
Josh@ottp
09-08-2015 11:18 AM
Quick Reply: Magnuson/Eaton TVS 1900
