Michigan
I have no interior lights..my cluster, hvac, or boost gauge will light up at night...checked the fuse..not blown...What I did was put the stock subwoffer into my trunk..and proceeded to drive down the street and noticed my cluster wasnt lighting up..I am confused beyond all hell and need help as I do a lot of driving at night
Any hints or something would be wonderfull.
you prolly have a short or a fuse some where. maybe relay? did u swap the fuse with a new one just to check and be sure? ive had fuses that were bad and you could swear it lookd fine.
Nope Fuse is 100% Fine
thats what has happened to me. I have seriously fried almost all of the fuses in my interior box at the same time doin some wiring in my car before. haha but its all good now. **** happens. also, look at all of the fuses. sometimes they link to other **** that isnt listed. i had to go thru all mine testing which one would turn on my key fob receiver so i could lock my doors remotely
when they fixed my car from a deer hit i had the same thing. check your brake light fuse because mine went bad and caused all my lights to quit.
Also check your day time running light fuse and parking light fuse in the engine bay I had the same problem and after I changed the fuse I found out one of my wires that goes to my headlight was shorting out and i fixed it and now everything is working great but I don't think u will have that problem
Hiro, being yours is 06, idk if DRL fuse matters, in my 07, it has no effect, i have the fuse outright removed. Seeing as my headlights are my DRL, ruined my HIDs ballast, lol.
Thanks guys..I feel dumb but It was the park lamp fuse..however when I put the subwoffer in and bolted it up..I somehow pinched a bundle of wires..which in turned caused a short and blew my fuse..all is fixed and I feel stupid for not seeing it earlier..
Macomb Collision|Collision Service Utica MI|Auto Repair Utica MI|Tire Service Utica MI|Auto Repair Sterling Heights|Powder Coating Utica MI|Collision Sterling Heights MI
Call them and ask for a quote, explaining what it is. If you want, tell them you know "andrew, chad's friend, and its like his spoiler on his car." Mention i recommended them, might lower it a bit more. They'll know which one, i'm there all the time.
