NE Ohio Thread FTW
#1181
Just the driver's side from that switch. Double checked the harness a few times (going to the switch) to make sure it was plugged in.
Not the power window fuse, otherwise all of the switches would stop working I'd assume.
#1182
I would check the window regulator and/or motor first. The switch is usually very dependable, unless you have had water get into it.
I would rather have it happen this time of year, it really sucks to when it happens in the winter, I know this for a fact.
#1185
Thats what I got so far. It's an alternating current. dk blue +, brown - to go up, vice versa to go down. If you test those and everything is kosher, it's a bad regulator in the door.
#1188
Did anyone else's stock boost gauge ever go out. Mine still lights up at night but doesnt move from where it sits When the car is off.(15 I think) I removed the a pillar a few times now to check the wiring and I'm not sure which goes to what and I have no clue how to fix it. Any ideas/solutions?
#1196
This all pivots on whether or not I can go, because like I've mentioned in other threads I'm moving that Friday and I need to get everything done that day or else I can't go
#1200
