Modern Performance Modern Performance is a Supporting Vendor
contacts: Modernceo
Cobalt Coilovers $999 have arrived! Pics!
Old 02-19-2008, 02:58 AM
  #176
Super_SS's Avatar
Originally Posted by Steven Flit
I havn't cut the bump stops in the rear. There is a 2 finger gap all the way around.
You may have sportlines; but you'll never touch the aggresive handling of these coilovers with those.
What size tires you running?
235-45-18 tire size..handlin is good,but i knw coils are better...only reason i bout springs was cuz i wanted the car to sit good and look aggressive..my wheel gap is 1 finger on the back,and can barelt sqeeze 1 finger up front..also no rubbing issue's at all
Old 02-19-2008, 03:00 AM
  #177
Steven Flit's Avatar
234/45/18; I rest my case
When I get 245/40/18s I'll have to raise my shocks and struts back up.
Old 02-19-2008, 03:01 AM
  #178
EmperorJJ1's Avatar
235s and 45 sidewall? interesting bc my 235/40 rub just a lil bit then again my shocks are probably shot
Old 02-19-2008, 03:03 AM
  #179
Super_SS's Avatar
40's gonna look to skinny bro...i wanted to go 40's,but all the potholes,speed bumps and crap,put alot of pressure on ur struts and ur rims are more likely to crack
i didnt even put 1k on my car after i bout it,and put that size tire on at 14k and now have 38k and no rubbing at all,and tires are still in brand new condition..about 80% thread life left on them
Old 02-19-2008, 03:07 AM
  #180
CobaltSS 16's Avatar
What tires do you have? Do you have an updated pictures with your tires and the sportlines.
Old 02-19-2008, 03:23 AM
  #181
Super_SS's Avatar
i have the bridgestone potenza re960as
dont have pictures of the set-up,but ill see if u can snap a pic later in the day
EDIT:i have 225-45-18...sorry for the mistake
Old 02-19-2008, 03:37 AM
  #182
EmperorJJ1's Avatar
tis makes sense... the 235s are sorta known for slight rubbing with the 40 sidewall 45 would be insane
Old 04-02-2008, 02:53 AM
  #183
jerm's Avatar
Is it hard to get all four corners evened out? Do you have to just adjust all of them by eye measurements or what?
Old 10-03-2008, 10:54 AM
  #184
BigBrother's Avatar
Was any prgress ever made on putting these on the Ion? I can't see why they wouldn't work as-is, but apparently some people think they won't. If you need a Guienea Pig, hit me up.
Can they be ordered with different spring rates from the get go? No use having extra springs laying around, and I need something a LOT more aggressive than 450ish front anfd 230ish rear, LOL - maybe 420 to 460 front and 480 to 550 rear as a ballpark. You know, for real driving.
Any possibility of camber plates, at least for the front? No instant camber adustment means highly unlikely I'll be on board unfortunatly, especially with the B&G set coming in only a couple hundred more with full camber plates and everything.
Still - I like the look, I like the manufacturer, I'm interested, but this thread seems to have dies off. ???
Old 10-06-2008, 05:38 PM
  #185
Modernceo's Avatar
These have pillow ball mounts for the front, as well as camber plates.
The rear, because of the factory design, cannot have pillow ball mounts or camber plates.
Im not sure if they will fit the Ion. If someone would purchase a set, we would take them back with a full refund IF they didnt fit and were not scratched, greasy, etc.
We've offered this before, however no one has stepped up to the plate to accept our offer.
Old 10-06-2008, 06:06 PM
  #186
BlilBT's Avatar
Thats about to change!
Old 10-06-2008, 06:37 PM
  #187
BigBrother's Avatar
Hmm. Well - what about the spring rate question firstly, and are the shocks retuned for stiffer springs secondly (or is the rate of adjustment sufficient for a much stiffer spring).
If I can get them with the spring rates I want and I know that the shocks won't be underdamping at full stiff with a 9 or 10k spring rate, then I'd probably be willing to give it a shot, becuse they really SHOULD fit. IIRC, the differences between our suspension (Ion and Cobalt) as far as mounting points are concerned apply only to front swaybars. The Koni shock insterts had a small issue in that the Saturn top hat was different, but that wouldn't matter with coilovers now, would it? And I'm putting in FE5 lower control arms anyway, so IF there's an issue there for some reason, it won't be.
Anyone know different?
Old 10-06-2008, 10:30 PM
  #188
KyleMinnis's Avatar
i should have done coilovers!
my buddy always gives me **** for just going with the sportlines:/
Old 10-07-2008, 12:03 PM
  #189
jhs87's Avatar
these will fit any model cobalt correct?
Like the 08 LS?
Old 10-07-2008, 12:12 PM
  #190
PimpLay2's Avatar
subscribe
Old 10-07-2008, 01:31 PM
  #191
freakta's Avatar
im still undecided on which to get airbags or coilovers
Old 10-07-2008, 05:14 PM
  #192
BlilBT's Avatar
Well mine should be here in a couple days & hopefully have time sat for the install.. got to cut the lawn & stuff 1st.
Old 10-11-2008, 06:14 PM
  #193
BlilBT's Avatar
Here is the thread I put up on them!
https://www.cobaltss.net/forums/show...=1#post2982079
Old 11-21-2008, 10:24 PM
  #194
cobaltracrtc's Avatar
do you think these coilovers can with stand the rigors of auto x and or grip racing becuase i want to upgrade from my sprint lowering kit
Old 11-21-2008, 10:37 PM
  #195
NWAE Cobalt's Avatar
i still wanty
wish i had the cash for these lol...
Old 11-22-2008, 08:30 PM
  #196
BigBrother's Avatar
They should stand up just fine to autox or track days; I would hope they're at least as strong - if not stronger - than the stock components they replace, which hold up fine.
I will be ordering these, but must discuss with the manufacturers the camber plate/pillowball problem.
Modernceo - I don't know how I didn't already know this, I never looked at my towers, I just ass-umed they were "standard"... The Ion's cannot use a camber plate/pillowball mount, as we have domed, not flat, single-bolt type strut mounts. Can these be had sans-plates? Also, about the available spring rates and shock tuning..?
Old 02-10-2009, 05:04 PM
  #197
ilovecars's Avatar
bump i want a group buy
Old 02-10-2009, 08:00 PM
  #198
chop em
and weld
Old 02-10-2009, 09:47 PM
  #199
Modernceo's Avatar
How many people would buy at say ~ $925 shipped ?
Heh. Thats a great way to fix it !
chop em
and weld
Old 02-10-2009, 09:49 PM
  #200
ilovecars's Avatar
although 925 is good stuff. i would have to save up another.......oh yea. 925 lol. no i only sugested it because by the time it might possibly happen i could possibly have enough money
Quick Reply: Cobalt Coilovers $999 have arrived! Pics!
