Innova CanOBD2 Scan Tool ! Check CEL's and ERASE them now too !
Now you can connect your car to a scan tool to check your CEL codes, and you can erase the check engine codes ! This unique scan tool will work on all vehicles from 96+ with OBD2 to check your codes, tell you if your vehicle will pass emissions inspection, and can erase/turn off your check engine code instantly !
"Helps to identify what’s wrong with your OBDII vehicle by quickly revealing check engine light warnings in cars, trucks, SUVs, domestics and imports. All in one display not only shows the code, but also it’s meaning. Will read for pending as well as active codes and has indication lights for emissions pass, pending or failure. CanOBD2 will also freeze frame code status, erase codes and link to PC for printing and updates!"
Kit includes:
CanOBD2
OBD2 Cable
Software CD
Serial PC Cable
Soft Nylon Case
3 AA Batteries
Pricing is $189.99 with $8 shipping.
Remember, this will work with all vehicles with obd2, trucks, cars, domestics, imports, and it will work with the new standard of OBD2, CANOB2. So one tool will work with your car, your moms car, your dads car, uncles car, best friends, etc ! You get the point !
Kit includes:
CanOBD2
OBD2 Cable
Software CD
Serial PC Cable
Soft Nylon Case
3 AA Batteries
