New Product Announcement: The WOT Box!
#301
#302
well, i just went down to best buy to buy a serial to usb cord. it was the only one there and it's made by dynex, it cost me 39.89 cents! but its cool, im just going to return it within 30 days and get my money back. do that stuff all the time
#308
hey smart guy. did you NOT read about the update? did you NOT read about setting the two step? guess not.
plug box into computer. download 2.3
plug box into car.
car happy.
i am tired of testing ****. thats why i have stopped testing ****. i made calls and did research before i hit "pay with paypal" on this little piece. what does my post count have to do with anything?
plug box into car.
car happy.
here let me post it for you,
"well area47 i think its cool you can upgrade it for free, didnt you even post you were tired of testing everything out cause you wanna wait too see what happens? and then you get the "out dated" version that only goes to 3k... what are the chances of that..."
god wtf is wrong with you... you didnt read it only goes to 3k on 2.2 which is what you got, i got 2.3 that goes as low as 2k.......... so quick to jump somones ****, you dont even read the post
#309
HAha! That's slick! Much better than the install I did....
Ok, if you have problems with it, make sure you install the latest drivers...
http://www.dynexproducts.com/skins/S...B9_Drivers.zip
I had problems with someone else using the drivers on the CD that shipped with it. Man, don't you hate when people ship their products with OLD software?
whoooopppssss....
whoooopppssss....
#312
whoooopppssss....
whoooopppssss....
yea, i was gonna say
#313
Well that was an exciting install. Only look me about an hour and a half due to ******* reasons.
Gotta say, for a stock car on stock tires, 2-step is just a bad idea. Even setting it at 3 grand I just smoke the damn tires off. I may return the box for just a WOT feature. I don't think the 2-step is really for me.... but my god is it fun to be able to just smash through the gears.
Video tomorrow.
Video tomorrow.
#315
Video tomorrow.
Video tomorrow.
so did you mess with the no-lift shift settings cause im curios as to what guys are going as low as... 200-300milisec??? it comes stock at 600
and another question so when you do no-lift shift what does it hold rpm at? your set rev limiter? (in my case thats too high, 7400rpm stock valvetrain) or the rpm it was at when you pushed in the clutch to grab the next gear?
ooops i meant twenty people have bought and you were the only one having problems...
butt your right im sure only about 5-7 actually have em installed already...
i hope i dont have any problems, and i hope you figure yours out
quick question does the car ever kick its self out of cruise control for no reason during normal freeway driving? this would support my theory, im just trying to look at this in a diagnostic perspective, just trying to help
Last edited by hungryhip-ccp; 07-18-2008 at 10:26 PM. Reason: Automerged Doublepost
#316
It completely cuts the ignition when you no-lift shift. It is not an RPM hold like the 2-step. Basically, we want as much deceleration from the engine as possible so that it matches up with the next gear as best we can. So, a complete cut is the best idea.
#318
I lowered this maximum to 350 ms in release 2.3 because we found that if someone missed the WOT Shift and we kept the ignition cut for more than 350 ms on the SRT it would trigger a code. Also, no one should take any longer than 350 ms to WOT shift.... 600 was too high a limit.
So, to summarize, in the default "auto" WOT Shift mode, it will just cut the ignition for the entire duration the clutch is down, up to some limit. The limit is there to keep you from stalling the engine....
Now, some people once they start shifting faster, they want more control over the cut time. Basically, they want the ignition to come back on slightly before the clutch is all the way back up. To do that, you set the manual mode and program your desired cut time based on feel...
I think the Cobalt SS TC is doing it the other way. They are using the 2-step for the no-lift shift as well. That is why the reviewer commented that there were multiple pops during the no-lift shift. That is because the 2-step was kicking in. While this might help develop more boost, I don't think you need it. It's easier on your transmission and it makes the shift less forceful if the engine is completely off. Plus, the dip in boost is practically unmeasurable, if you shift fast enough...
You should get 2.3.
It looks like it will only work right now on the 07+ 2.2 Cobalt. The way the software works right now it requires a coil-on-plug ignition setup. If you have that, you're good to go. If not, I'm working on a more generic software load that should work with just about anything else...
Video tomorrow.
Video tomorrow.
#320
#324
