N2MB Racing N2MB Racing is a supporting vendor.
Contacts: phrozen ; jay@n2mb
New Product Announcement: The WOT Box!
Old 07-20-2008, 10:31 PM
  #376
ItalianJoe1's Avatar
Originally Posted by 06blackg85ss
got the Hahn one in there now, works flawlessly
How's it sound??
They make it themselves? Thats pretty neat if its the case.
Originally Posted by phrozen
Eventually, all these parameters will be customizable through the Windows software.
Now that sounds interesting...
Old 07-20-2008, 11:42 PM
  #377
BlackSS/SC's Avatar
Sure, we can change it. So you were trying to 2-step, and it didn't engage because it revv'ed up too fast before the gas was all the way down? Did you really stomp the gas or ease into it?
I think it's just my driving habbits. When I used to do a 2nd gear burnout with the slicks I'd rev it up with a couple pumps of the gas and them drop the clutch. Now I find myself doing that over and over and then trying to engauge the 2-step and drop the clutch.
Old 07-21-2008, 07:14 AM
  #378
06blackg85ss's Avatar
[QUOTE=ItalianJoe1;2625566]How's it sound??
QUOTE]
Made through turbosmart, sounds awesome, pretty loud though
Old 07-21-2008, 08:49 AM
  #379
phrozen's Avatar
Ok, I'll make a test load for you with the limit raised to 2500... Or do you want it turned off completely?
Old 07-21-2008, 10:07 AM
  #380
BlackSS/SC's Avatar
How about making it 3000rpm, or what was it on version 2.2? I don't want it turned off totally though.
Old 07-21-2008, 10:19 AM
  #381
Rent me! per hour
Area47's Avatar
you barely touch the clutch pedal, it activates the ignition cut. you lightly rest your foot on there between wot shifts, it cuts.
two clutch switches on the same circuit.
however. if done right. the blower cars will have a loud bang out the exhaust right after a 2-3ft flame exits the ass end of the car. it is not quiet by any means when it happens. think bikes on the bottle with an air shifter pop
Old 07-21-2008, 10:26 AM
  #382
phrozen's Avatar
I'm confused. Did you look and see if there is an adjustment on the clutch pedal position switch? You may be able to adjust the point at which the clutch switch triggers.
We need to use the upper switch, because the lower (starter interlock) switch takes too long to be triggered during a shift, and some people may not hit it at all. So, the upper clutch pedal position switch is the switch of choice, but you just may need to adjust it to suit your driving style....
It didn't exist in 2.2. You could 2-step on the highway.
The idea here is that it should be an indirect measure of speed. Some people don't want the 2-step to engage while moving, otherwise it will be triggered on an aggressive upshift. So, you want it to be low enough that if you were cruising in 5th or 6th on the highway, then clutched in, upshifted and stomped the gas before fully letting out the clutch, you wouldn't trigger the 2-step... or maybe in that situation you would want the 2-step... Some people do, some people dont.....
Old 07-21-2008, 10:33 AM
  #383
Rent me! per hour
Area47's Avatar
it's a wot driving style change. the two clutch switches are on the same wire at the ecm. one breaks a circuit, they both break it. it's a gm. i stopped asking why a long time ago.
the top one is for cruise disengagement
the bottom is for the starter interlock. both are on the same wire at the ecm.
Old 07-21-2008, 10:39 AM
  #384
black06ss's Avatar
perhaps tap the bottom one with the appropriate wire instead of at the pcm. maybe im just a knucle head though, or then again maybe im a correct knucle head.
Old 07-21-2008, 10:40 AM
  #385
hungryhip-ccp's Avatar
yeah no adjustment either i checked last night
Old 07-21-2008, 10:45 AM
  #386
Rent me! per hour
Area47's Avatar
one breaks, they both do
already crossed my mind. discussion with someone else about this saturday night confirmed it.
you hit the clutch pedal at the wrong time at wot. you're eating the steering wheel
Old 07-21-2008, 10:50 AM
  #387
phrozen's Avatar
I don't think they are on the same wire. Take a look at pins 53 and 54 on the ECM:
https://www.cobaltss.net/resources/pcm/05cobalt20.htm
You can try the lower one, but I think it will activate too late....
Old 07-21-2008, 10:51 AM
  #388
BlackSS/SC's Avatar
OK, I'd like to not have that limit at all. So no block out from the 2-step but with the new "auto" adjustment from 2.3.
How do I get this? You email it to me? If so you can PM me and I'll PM you the email address.
Old 07-21-2008, 10:53 AM
  #389
Rent me! per hour
Area47's Avatar
i'll just adjust my driving style, or disable it. one of the two. however, hammering third at 7600rpms and the clutch not going zing is effin great
Old 07-21-2008, 10:58 AM
  #390
phrozen's Avatar
Yeah, I guess if you avoid riding the clutch, it should be fine. Also, you could try adding a pull-up spring on the clutch pedal like you mentioned. Or maybe there is some brute force way to change where the switch engages, like slightly bending its mounting bracket or filing down the button a bit.....
Old 07-21-2008, 11:02 AM
  #391
black06ss's Avatar
thats what i figured knowing you just thought id throw it out there. well i attempted to think today so now im spent.
Old 07-21-2008, 11:11 AM
  #392
phrozen's Avatar
Here you go:
http://www.npcompleteperformance.com...O_DUAL_2.3.EXE
http://www.npcompleteperformance.com...SINGLE_2.3.EXE
"NO_LO" means no lockout feature
Make sure you use the "DUAL" file if you have both no-lift shift and 2-step. Use the "SINGLE" file if you have only one feature or the other.
  #393
i want this too... ope never mind ^^^ thank you
Old 07-21-2008, 11:12 AM
  #394
phrozen's Avatar
Originally Posted by hungryhip-ccp
i want this too...
look up... It's posted above...
Old 07-21-2008, 11:14 AM
  #395
you beat me too it? once again nothing but good things from you so far
Old 07-21-2008, 11:33 AM
  #396
copson20's Avatar
is there anything for the 2.2's
Old 07-21-2008, 11:39 AM
  #397
BlackSS/SC's Avatar
Thanks phrozen!
Old 07-21-2008, 12:18 PM
  #398
phrozen's Avatar
Right now, we only support the 07+ 2.2s. As far as I know, these are the only 2.2s that have COIL-ON-PLUG ignition. I'm working on some new code that will support everything else that doesn't have coil-on-plug ignition and hope to have it available by next week or so.
Old 07-21-2008, 12:44 PM
  #399
lol yeah I did that once already. I didn't know what happened at first.
Old 07-21-2008, 12:52 PM
  #400
Rent me! per hour
Area47's Avatar
i've done that 3 times so far. a friend was in the passenger seat. his head hit the dash
then i was runnin a friends speed6 and hit 3rd with my exhaust right next to his window. it popped hard. hehehehe
ain't i a stinker
Quick Reply: New Product Announcement: The WOT Box!
