New Product Announcement: The WOT Box!
#528
the first one is without the wotbox, i can hear the clutch slipping out without alot of rpm drop or the clutch needed a little heat in it
i really couldnt tell but it sounded like the 2nd and 3rd were on auto and there was a big rpm drop
the 4th sounds about somewhere near 175-200ms
the last one sounds like somewhere around 75 ms
judging by the movement of the clouds and the weather report for your area in the past couple days with normal winds the timeframe you filmed this in was very narrow.the clutch may have needed some cooldown time between runs and runs 2-5 would have burnt a little more rubber
#529
damnit I'd post some vids but my car is out of action, clutch just arrived yesterday, install on the 16th hopefully. Vids and track time a week or so after that. After being at E-town saturday for pinks all out, I can't wait to get my car back on the track.
oh and your box worked pretty damn good in my friends srt last weekend. Finally got it adjusted for him for the second run, too bad they wouldn't give him his times.
http://videos.streetfire.net/video/e...-on_173937.htm
#530
also, there was no clutch slippage in any of these, the road is not really a great road and the tires were not making much noise on initial hit in 2nd. they broke lose every time so the "clutch slip" you hear is actually the tires spinning for a split second
1st- off the box, felt like the best to me
2nd- 25ms
3rd- 75ms
4th- 200ms, seemed slow as hell
5th- 50ms
6th- 125ms
imo the more "tirespin" is not indicative of a great shift or not for the most part.
#532
ill post up which each ones were, you are a little off
2nd- 25ms
3rd- 75ms
5th- 50ms
6th- 125ms
2nd- 25ms
3rd- 75ms
5th- 50ms
6th- 125ms
im gonna have to disagree with you here! numerous people have felt your clutch was slipping but your blind to the fact that it is... the first one was pretty bad that was with no box thats why i feel this is a great product it helps eleminate clutch slip, and its not the clutch that the weak point its the pressure plate is not strong enough... when ever someone replaces there clutch cause there upgrading, the clutch looks brand spanking new but wont hold? cause its a weak pressure plate not a gone/weak clutch...
the last one was the best... your right tire spin dosent equal speed
but it does equall power being put to the ground which equals faster times at the track were the tires actually will hook (or when better tires are put on like DR or slicks)
gotta get over the whole clutch slip thing before you will realize a upgraded clutch alone will probably drop your et's by a few tenths... all of this is just my opinion not trying to argue...
#533
i think you and i can both agree that you get way more feedback in a car than you do watching videos. correct? the clutch hits hard on all these, and i do feel that the regular speed shifting method is quicker. just my opinion though. i too have been wondering which would actually be easier on the clutch
#535
im not going to argue about it, and im not "blind to the fact"
after i read that it seemed a little uncalled for so sorry for my lack of better words
#537
#542
i feel like an ass for assuming and calling you out when like you said im not there or in the car... sorry stu... i just know my car sure as hell slips the clutch on the 1-2 without the box! so my bad for assuming your was as well
#546
#547
No. We still cut ignition, but we use the fuel injector control signal for timing reference. It works the same, just a slightly different software load. I am working on combining them so we can run the same code on both wiring setups.
#550
Rent me! per hour
ya know, i never really use mine anymore. i think it's a novelty factor more than anything else.
a lady was drinking a coke the other day at a stop light and i hit the two step. she dropped the coke
