New Product Announcement: The WOT Box!
#576
yep pm replied
#580
Sounds like an unrelated code. Try clearing the code and then driving around for a few days without using the WOT Box (don't WOT shift and don't 2-step launch). See if the code comes back on its own. If it does, then the problem is unrelated.
#582
Here are three software loads for you to try out.
1500 RPM lock out (stock):
http://www.n2mb.com/wot_box_GEN_1500_LO_DUAL_2.4.EXE
http://www.n2mb.com/wot_box_GEN_1500_LO_SINGLE_2.4.EXE
2000 RPM lock out:
http://www.n2mb.com/wot_box_GEN_2000_LO_DUAL_2.4.EXE
http://www.n2mb.com/wot_box_GEN_2000_LO_SINGLE_2.4.EXE
2500 RPM lock out:
http://www.n2mb.com/wot_box_GEN_2500_LO_DUAL_2.4.EXE
http://www.n2mb.com/wot_box_GEN_2500_LO_SINGLE_2.4.EXE
Let me know how that goes. Start with the lowest one. You want to make sure it is still able to keep you from accidentally engaging the 2-step while you are moving.
Also, make sure you really get on the gas quick when you want to 2-step so that it doesn't have time to rev much before you get to WOT. That was the original problem, right? Your motor revs so fast with no load that it is above 1500 RPM before you can get to WOT?
If you need the instructions for the upgrade, check them out here:
http://www.n2mb.com/wotboxsoftware4
#587
interested in this wot box for my redline where do i order it for the wot shjift and 2 step option??
and one question thoe....if the 2 step is set low enough will it activate during daily driving or only when the gas pedal is firmly pressed in at idle??
thanks im interested now!!!
#589
and where do i order one for my redline??? i dont want to order the wrong thing haha..cuz i dunno if the cobalt and redline have different wiring or such
#590
wut do u mean the 1500 rpm limit???? what im sayin is does it only activate once u floor the gas pedal??? or does it just start when it reaches that rpm??? cuz if not ill jsut keep it at 2500 rpm the whole time lol
our website is http://www.n2mb.com/wotbox when you are ready to check out.,
let me know if you have any more questions.
thanks
#591
The 1500 limit is for engaging the 2-step. It doesn't allow the 2-step to engage if the engine is above 1500 rpm before you go to WOT. That prevents it from kicking on the highway. There is also a 2500 rpm lockout for some that prefer it.
thanks
thanks
#594
Everyone needs to read the warning clearly. NOT FOR USE WITH EXHAUST THAT HAVE A CAT!!
I blew mine out in about 2 months.
Took the WOT box off, took car to dealer, they replaced CAT, WOT box stays off until I'm catless now.
#597
actually no, i rarely used it. I got bored after the first week and a half and only used the WOT shift part of the box. in that two months time, used it probably.... 11, 12 times tops.
#600
well yea. i'm not saying anything bad about the WOT box. just for people to be aware that they're not kidding when they say, not for cat use.
i <3 this company and their product. eeze off a bit man, jeeze
