N2MB Racing N2MB Racing is a supporting vendor.
Contacts: phrozen ; jay@n2mb
New Product Announcement: The WOT Box!
Old 07-17-2008, 05:28 PM
  #201
hatrickstu's Avatar
Originally Posted by ColeJJones
yea me too. i dont like the soddering part. i wonder if i can just do wire taps instead
i would do the soldering man, way stronger and you can make it look factory. you could not look on my car right now and see any signs of it
Old 07-17-2008, 05:45 PM
  #202
adamo41188's Avatar
whats the difference between no lift shift adn flat foot shifting? isnt it the same thing?
Old 07-17-2008, 06:00 PM
  #203
06blackg85ss's Avatar
ha I have no power outside since I'm moving, had to use crimp and tap connectors (hence no photos up at the moment, it looks like crap lol) redoing the wiring this weekend to clean it up a bit
Old 07-17-2008, 06:10 PM
  #204
Rent me! per hour
Area47's Avatar
so you don't have to cut and move wires? simple t connector would work?
Old 07-17-2008, 06:12 PM
  #205
you do have to cut the pink wire to the coil's though, that is a must
Old 07-17-2008, 06:17 PM
  #206
Rent me! per hour
Area47's Avatar
well crap.
then again. the pink wire is a universal gm coil signal anyways
Old 07-17-2008, 06:24 PM
  #207
yup, no issues with mine so far. None of my friends running this (quite a few) have had amy problems
Old 07-17-2008, 06:33 PM
  #208
Rent me! per hour
Area47's Avatar
any of said people with this box have an 07? or am i test monkey again
Old 07-17-2008, 06:46 PM
  #209
06black's Avatar
you'll be fine bitch.
Old 07-17-2008, 06:52 PM
  #210
phrozen's Avatar
how many blinks is that?
http://www.npcompleteperformance.com/wotboxusersguide
according to that link, it can only go down to 3000
There's a new chart that goes along with firmware 2.3 (which is what you guys have):
http://www.npcompleteperformance.com/wotboxsoftware4
I need to update the user's guide... If you try to change the RPM, you should notice that it is 1000 RPM lower than posted on the original guide...
Old 07-17-2008, 06:54 PM
  #211
Rent me! per hour
Area47's Avatar
wire colors the same through 06-07 i take it?
Old 07-17-2008, 06:59 PM
  #212
phrozen's Avatar
Same thing. It's just shifting while keeping your foot on the gas.
Yeah, I wouldn't recommend them either. If they work loose from all the vibration you could have some wacky stuff, like the 2-step engaging in gear.... Not good. Make the connections solid and solder them.
Originally Posted by Area47
well crap.
The pink wire is the power to all the ignition coils. We cut power to the coils, so it has to be cut and the WOT Box RED / BLACK wires spliced in.
i got my **** into early, i never doubted you guys for a second anyways, its a cluster **** of wires, ties, tubes, and other hooyas, the how to looks pretty damn intimidating. i will probably make my own how to... maybe
Please do. I welcome improvements to my directions. They could always use clarification.
  #213
hatrickstu's Avatar
im positive mine has the 2.2 on it bro. i had it set on 1 blink and it was 3,000.
Old 07-17-2008, 07:14 PM
  #214
phrozen's Avatar
Should be. The test car was an 06, I believe. For the coil power, go by the pin location, not the wire color. That might vary a bit...
Hmmm.... That is odd... Maybe Jay flashed them accidentally with 2.2?
Ok.... Well, if you want the lower 2-step RPMs then you should upgrade to version 2.3....
Ok, it looks like Jay read the site wrong and loaded everyone with 2.2 instead of 2.3. The differences are minor and you can upgrade your WOT Box yourself, if you want to. I've added a link to the firmware page for the Cobalt on the Software upgrades page:
Sorry about that. All new orders will be shipping with 2.3 now...
Old 07-17-2008, 07:38 PM
  #215
jay@n2mb's Avatar
hey guys my apologies i loaded the previous flash on the wotbox so 2 step will be min 3k. i apologize for that once again the newest flash (2.3)is available on our site.everything will work as designed in the 2.2 with the exception of the lower 2 step parameters(2k-3k)
Old 07-17-2008, 07:39 PM
  #216
Maxim_X's Avatar
I placed it. What perfect timing. I've been having a lot of trouble getting my car out of the hole since I went turbo.
  #217
Bannned
ColeJJones's Avatar
so my **** is old now?
Old 07-17-2008, 07:49 PM
  #218
06black's Avatar
yes sir.
if you run into issue by i can shoot you diagrams and such.
  #219
ItalianJoe1's Avatar
Just curious, what other changes to the 2.3 update?
Old 07-17-2008, 07:54 PM
  #220
powerz's Avatar
are there tracking numbers for our shipments
Old 07-17-2008, 07:56 PM
  #221
Opi
Opi's Avatar
-I'm going to assume I can't update the software off the Mac platform can I? I'll have to duel boot into windows? Am I correct in this assumption? (Nevermind, I realize it's a .exe file now. Boo for lack of mac support)
-Where do we go to get the power cord again? The only way I'm going to be able to update mine is in the house. No lappy for me.
-Will the 2-step activate while the car is in motion? I.E. Can we build boost before dropping down the clutch? Give the car a little extra "oompf" to get past someone on the highway?
Old 07-17-2008, 09:42 PM
  #222
dw2b22's Avatar
Ok so add me to I just bought one I have an 04 Redline though so will be needing the information to make it work. Thanks
Old 07-17-2008, 09:50 PM
  #223
Rodimus_Prime's Avatar
where do i order>
Old 07-17-2008, 10:07 PM
  #224
In that case, the car already has a load on it, you could just step down and let the car boost up, it won't take long. The reason for the two step is that you can't get the turbo to spool by just revving an engine that is unloaded, it takes so little throttle opening to rev the car up that it can't get enough air to spool. The 2-step lets you hold the throttle wide open and controls the rpms of the engine, letting you get boost before placing the car under load (launching)
Old 07-17-2008, 10:29 PM
  #225
phrozen's Avatar
In the 2.2 release, you could 2-step while the car was in motion. In the 2.3 release, I disabled that to prevent it from inadvertently activating on a hard downshift. In the next release, I will make the lock-out a programmable option so that people can choose to turn it on or off.
Let me explain it better, in the newest release, there is a 1500 RPM lockout. The lockout requires that the engine be below 1500 RPM before you go into WOT with the clutch down before the 2-step will activate. If you are above 1500 RPM (i.e. you are moving, it won't activate).
Quick Reply: New Product Announcement: The WOT Box!
