New TVS build! Advice?
Old 09-25-2015 | 03:16 PM
Area47's Avatar
Rent me! per hour
Originally Posted by Price_is_Right
Ive been told zach is pretty well known around the midwest. I have bought a few parts off of him and he sent them immediately,etc. I do somewhat know a guy named Bryan Higgins that could possibly tune my car. I've heard he's the best around where I'm from. Any reviews on him?
I am the person you're inquiring about. Most people who know me, know this screen name, not the real name on facey spacey.
I fly well under the radar on facebook groups.
Old 09-25-2015 | 05:04 PM
Price_is_Right's Avatar
Oh well whats up lol I'm friends with you already on Facebook. The name is Levi Price. I'll probably be looking for a tune here in a month or so. I'm putting on exhuast and cooling mods tonight
Old 09-25-2015 | 05:09 PM
Area47's Avatar
Rent me! per hour
right on. If you want to discuss stuff, I will be in omaha next weekend for some shenanigans.
Old 09-25-2015 | 05:10 PM
Alright Area I'll message you on FB
Old 09-25-2015 | 06:58 PM
Builttss's Avatar
Come to floridaaa area lol. Im no longer in omaha
Old 09-28-2015 | 04:48 PM
Area47's Avatar
Rent me! per hour
at some point in time i will.
Old 10-16-2015 | 02:28 PM
UPDATE!
My exhaust is finished finally.
ZZP Shorty Header
ZZP 3" 200 cell High Flow Catted Downpipe 2.5" exit w/ extra o2 bung for wideband
Tsudo N1 2.5” Catback 4.5” tip w/ resonator
I also got ZZP Dual Pass, ZZP secondary heat exchanger, option b with ZZP mount installed
Still waiting on my intake from OTTP....tic-toc tic-toc
Couple questions...
I was wondering if these mods are worth the buy and/or other companies that make them better?
ZZP Front Strut Tower Bar
ZZP Rear Sway Bar
ZZP Rotated Front Trans Mount
ZZP Rotated Rear Trans Mount
Old 10-16-2015 | 03:09 PM
Staged07SS's Avatar
Administrator
Administrator
UPDATE!
ZZP Shorty Header
Couple questions...
ZZP Rear Sway Bar
ZZP strut tower bar - no waste of money. our struts are attached to the fire wall and inner fenders. Next to no flex.
ZZP rear bar - Rear sway bars def help, but I'd go with one that bolts through the bar. Not a fan of the brackets ZZP uses for their bar.
ZZP rotated mounts - back in the day they were proven not to be actually rotated. Maybe they changed that. If so, then snag them up. If not, pick up powells.
Old 10-16-2015 | 07:18 PM
Can you hook me up with a link to Powell products? Never heard of them before. Thanks.
Old 10-16-2015 | 11:37 PM
Just send an email to gloria think theres info in the op somewhere. Powell trans mounts nuff said
https://www.cobaltss.net/forums/gene...powell-296456/
Old 10-16-2015 | 11:42 PM
  #36
Also ur goals seem a little optimistic check out these numbers for a decent referance of what you need for upper 300s
mrbelvedere, 401whp, 314wtq, Verified Dynojet, TVS1320/2.8/160s/I/F/C/ATI/RS/E85/FI/T/PH/H/CD/E/N20[50],Â*Graph
3. Coreyallan, 396whp, 305wtq, Verified Dynomite, TVS1320/2.6/100s/E85/I/F/DP/E/T/CD/FS/PH/C/TB,Â*Graph
4. freakta, 389whp, 322wtq, Verified Dynojet, TVS1320/2.5/60s/I/H/DP/E/RS/TB/PH/C/VS/IM/IC/FI/PI/OB/RG/T/STR,Â*Graph
5. JapEatr, 383whp, 291wtq, Verified Dynojet, TVS1320/2.6/ATI/I/H/DP/CD/E/T/E-85/PI/TB/1000s/DU/PD/RS/FS/C/FI,Â*Graph
6. riceburner, 380whp, 283wtq, Verified Dynojet, TVS1320/2.8/98s/RSFS/FPRW/E85/ATI/BS/PH/C/TB/I/H/DP/E/T/VS/OPTB/DU/HE,Â*Graph
7. Advise, 376whp, 286wtq, Verified Dynojet, TVS1320/2.7/98s/I/H/DP/E/T/DU/HE/RS/CD/C/PH/FS/E85,Â*Graph
8. Area47, 374whp, 315wtq, Verified Dynojet, TVS1320/2.5/98s/I/H/DP/CD/E/E-85/T/PH/VS/RS,Â*Graph
Legend:
I = Intake
F = Filter
H = Header or Aftermarket/other than stock Turbo Manifold
GMH = GMPP Extrude Honed Manifold
GMHP = Ported GMPP Extrude Honed Manifold
DP = Aftermarket Down pipe
E = Cat-back exhaust
T = Tuning
P = Underdrive Pulley
DR = Drag Radials or Slicks
DU = Dual Pass
98s = 98# injectors
80s = 80# injectors
79s = 79# injectors
60s = 60# injectors
50s = 50# injectors
42s = 42# injectors
RS = Return style fuel system
N2O[shot] = Nitrous + shot
0.0 = Will specify pulley size for the SS/SC's
WI = Water/Meth Injection
PB = Ported Blower
GM1 = GM Stage 1
GM2 = GM Stage 2
GM3 = GM Stage 3
I-STGx = Intense Stages
CD = Cat Delete
HE = Aftermarket or 2nd Heat Exchanger
TB = Ported or aftermarket throttle body
PH = Ported, aftermarket head/headwork
IM = Ported,aftermarket, or better than stock intake manifold
C = Cams
M62 = Stock Supercharger off a Cobalt SS/SC
H62 = Hybrid M62
TVS1320 or TVS1900 = TVS supercharger
TS = Twin Screw supercharger
TWNCHRG = Twin Charged (turbo and supercharger)
TK = Turbo Kit
RG = Race or above 93 octane gas
AM = Airbox mod
IC = Intercooler
CP = Chargepipes
FI = Forged Internals
ZZPtck = ZZP turbo conversion kit
ZZPtk= ZZP turbo kit
CO = Exhaust cut out
PCK = Procharger Supercharger kit
MD = Muffler Delete
K04 = K04 turbo
PI = Pistons
E85 = Ethanol Fuel
FS = Fuel System upgrade
STR = Stroker (anything with a longer stroke than stock)
OB = OverboreÂ*
GM1S = GM Stage 1 Sensors (SS/TC)
BS = Balance shaft delete
OPTB = Option B
VS = Valve springs
FPRW = Fuel Pump Rewire
Old 10-17-2015 | 03:06 PM
  #37
Yeah I kinda figured it would take a little more to get to high 300's. Ill get there someday. But for now I want to at least get over 300 with the stuff I have
Old 10-17-2015 | 04:24 PM
  #38
Thats doable best of luck!
Old 10-21-2015 | 08:16 PM
  #39
Thanks! I'll probably continue to post on this thread as I go along with my build. I just bought all new tires so yay winter
Question:
I was looking into installing a return style fuel system and just wondering if anybody has any reviews from zzp's current product. And if there's an installing guide with pictures somewhere. And I was wondering if you need to tune for it. Thanks!
Old 10-22-2015 | 11:07 AM
  #40
07blackg5's Avatar
Slobodan Milošević
You only need to tune if you hook up the vac port. If you don't connect the boost reference port, you can set the pressure to ~58psi and not make any other changes.
Old 10-27-2015 | 08:43 PM
  #41
SportTouringSedan's Avatar
Great thread and great premise of a build.
Old 10-28-2015 | 03:55 PM
  #42
seem to have a good handle already on what you need. didn't bother reading anything other than OP but mounts are good purchase, as is clutch.
Old 11-03-2015 | 06:40 PM
  #43
Any suggestions on what to do for my suspension? I hate the wheel gap so I was thinking to lower it a tad bit but wanting to keep the ride handling well. Maybe coilovers? What type of struts, shocks, etc.
Thanks!
Old 11-03-2015 | 06:48 PM
  #44
CobaltSS 16's Avatar
go with coil overs if you wanna go low and have good handling. Some run konis struts/shocks with a lowering spring of choice. Those are nice too for moderate drop and good at the track.
I personally have stance coils.
Old 11-14-2015 | 03:54 PM
  #45
Thanks! I dont know much about suspension stuff. Is there a specific name brand that sells a coil over kit thats good quality?
Old 11-15-2015 | 02:48 PM
  #46
check out thmotorsports.com or turbotechracing.com
most popular coil overs are BC racing or Stance coils. Some people run ksports... which are a couple hundred dollars less then the stance and BCs.
Old 11-17-2015 | 08:23 PM
  #47
Alright ill check them out.
Old 11-24-2015 | 03:03 PM
  #48
Any suggestions on what to do for struts and control arms? Mine started getting a little squeaky, but I'm guessing its just from the cold. OR if there is just a kit I can buy that basically replaces your whole suspension lol
Old 03-07-2016 | 02:22 AM
  #49
Coreyallan's Avatar
Hope to go from #3 to #1 this summer, that would be nice
Old 03-07-2016 | 09:41 AM
  #50
Haven07's Avatar
I just replaced my struts and springs this past weekend, I went with Koni adjustable shocks in the rear, lnf oem front struts, and Ottp lowering springs. It's an amazing set-up.
Quick Reply: New TVS build! Advice?
