My Zex Nitrous Install
Moderator Alumni
Hey guys, picked up a Zex kit this weekend and I am in the midst of installing it now.
Right now I am hung up waiting for some longer lines (4ft) so I can mount my ZEX NMU modules more out of the way. I am planning on running the shot through the supercharger so I will report back on it if I have any problems, but it seems other have done the same type of install with some sucess so I am going to give it a shot.
It's a Zex Wet EFI 82021 kit and it's a 55-75 shot.
Here are some pictures of the install in progress.
The Tank
The engine bay.
The Arming switch
The Fuel tap off the schader valve
A close up of the ZEX module mounted on the passenger side wheel well.
The wiring mess, this is actually a little accessory fuse block I installed under the radio, it handles my wideband, my Interceptor gauge, and my inline FM modulator and now my nitrous system. You can't really tell whats going on in there but I promise to clean it up before I button up the car.
The Tank
The engine bay.
The Arming switch
Moderator Alumni
Originally Posted by IonNinja
why aren't those lines long enough? where are you planning on mounting the unit?
I put my solenoid and purge valves right behind the grill of the car, wish I had some pics to show you guys. It purges right below the bowtie on the grill. Control box and all the solenoids are visible through the grill, it look super sweet...Had the zx kit on for almost a year now, good luck with the rest of the install. Welcome to the Sprayers Club...
Moderator Alumni
Originally Posted by Woodyr007
I have a question. I have a dry shot kit. Can I make it a wet shot? Prolly a stupid question just asking, because I am to afraid to spray before the SC. Thanx
Most of the vendors sell a dry to wet upgrade kit. Pretty sure Zex does.
Looks awesome Zinner, now you just hafta clean up the lines a bit, but I assume that's why you wanted the extra 4 ft for, lol.
Can't wait to hear how the engine likes the shot before the blower. It should be fine Grand Prix guys have been running it that way forever.
Moderator Alumni
Oh yeah I have cleaned up the wiring with some loom after the pictures were taken and the lines are just wire tired for now to keep em outta the way.
correct me if wrong, but how can u run a wet shot threw the supercharger?? wet shot is a mixture of nitrous and fuel. a dry shot is just nitrous threw an intake or before the trottle body. why would run a wet shot threww the supercharger?? i must of heard wrong sorry to bash, just askin lol!!! i also heard theres a teflon in our supercharger which starts to come off if we use nitrous. i think best desion on nitrous is just direct port,,,,safest what do u all think???????
A wet shot is a mixture of fuel and nitrous correct. It usually is introduced before the throttle body as well....basic wet shot. Very safe. More advanced wet shot is direct port.....drilling and tapping each individual, and having 4 nozzles. Wet is the safest way to go because it adds the extra NEEDED fuel. As far as introducing it before the super charger, yes it does increase the likelyhood of premture impellar wear.
Here ya go. The driver side is pretty crowded in the cobalt so I figured it would look nicer on the passenger side.
Moderator Alumni
right I see that, but it looks like those are lines are more than long enough. I was thinking of mounting it like 05YELLOWSS did his kit. Looks like the best place to me...thats where I plan to mount mine eventually as well.
The lines wsith the kit at 24 inches and they aren't long enough.
I just got the 4 ft lines in today and they are the perfect length.
Do you have some pictures of a better way or even a description?
HEy zinner, so how is it. Does it pull alot stronger at the top of the gears? Just curious, I am sitting on the ZEX page trying to decide if I should order the wet upgrade of not!!! Thanx
seriously though, have you engaged warp speeds yet? My other question is why put the switch by the stick? You know if you have a passenger they will be tempted to play with it there. I would have mounted it in that area where the trunk release was at so it's not in plain sight regardless
For those of you looking at the machine gun kit, don't waste your money. You can pulse it with your finger just as fast, and it is no louder than a regular purge. Kind of misleading on Zex's part. Better off just getting and LED purge and hitting the button quick...... I'm a lil angry I spent the additional 100 bucks.
