Nitrous Oxide N20
Is Nitrous the easiest way?
Old 10-05-2006, 04:18 PM
  #76
slowion2's Avatar
well right both have downs, BUT I woudln't run a dry shot on these cars at all. maybe if you could setup a standalone to control fueling for when the dry shot is active, but we've never had much if any luck with returnless systems running dry. we're lucky that the intake manifolds in the ecotecs aren't prone to puddling, there are some cars that the safest way was to run a direct port only because of this.
Old 10-05-2006, 10:11 PM
  #77
c0baltic's Avatar
well i just ordered the estra parts i need to change to a wet system. i will post pics and a how to once it is all installed.. i think the hardest part will be finding a place to mount the switches.
-drew
Old 10-06-2006, 01:54 AM
  #78
Fatalis's Avatar
Switch placement in the ION was easy as hell. Because i had the base level ion, i had a bunch of free switch places open, and autozone carried the exact size switch the ions use for the console holes/switches. So my nitrous looks like it came with the car lol.
Old 10-06-2006, 09:01 AM
  #79
slowion2's Avatar
^wonder where you though of that lol
seriously though c0baltic, to me, mounting switches is the hardest part of the entire install. you want them accessable but not out in the open and then you can have issues of clearance for the terminals behind it...just make sure you try to plan this out somewhat early instead of when it's the last thing to do.
Old 10-08-2006, 06:06 PM
  #80
Fatalis's Avatar
Eh, i dont remember where youre arming switch is. I just saw the hole i think and threw in the switch. now the window switch i copied, because it fits perfectly.
06blackg85ss
83
01-18-2017 04:35 AM
Decepticon06ss/sc
10-16-2015 09:24 PM
TylerJHowell
09-21-2015 06:47 PM
ncstateredline
09-10-2015 07:22 AM
Brian MP5T
Nitrous Oxide
18
11-20-2005 06:53 PM
Quick Reply: Is Nitrous the easiest way?
