North Central ND, SD, MN, and WI
Wisconsin Thread (Team Rev & Others)
Old 02-16-2012 | 06:21 PM
  #4151
ahkeelyou's Avatar
wisconsin FTMFW
Old 02-16-2012 | 10:55 PM
  #4152
robertmichaels's Avatar
Originally Posted by stealthy1ss
Then best advice I can give is make sure that your brakes are ready. That means you need minimum HP+ pads with DOT 4 brake fluid with decent rotors not drilled. With a tune make sure that the timing is backed down some from normal because you will be at WOT a ton. If you have a LSJ with blower make sure you have some cooling mods or else you can say good bye to your motor.
Yes bring a helmet and WEAR PANTS!!! Shorts are not allowed.
For mods I have:
-ZZP S3 FMIC
-Dual Pass
-Option B
-New IC Pump hooked up the right way
-LSJ Phenolic Intake Spacer
-Step 2 colder plugs
-Eaton boost controller
For brakes...well we will see what's left in my budget after rims and tires
Old 02-16-2012 | 10:58 PM
  #4153
stealthy1ss's Avatar
Originally Posted by robertmichaels
For mods I have:
-ZZP S3 FMIC
-Dual Pass
-Option B
Trust me you need to spend a little money on your brakes or you will endanger yourself and everyone on the track with you. I have lost my brakes on the track before and it is super scary. This is very serious.
Old 02-16-2012 | 11:06 PM
  #4154
padlock's Avatar
as long as we are on the topic..
I am easily considered a newb when it comes to autox but its something id be interested in trying a couple times this year for the first time.
what kind of class would I even be put into considering I'm a fully bolted/tuned 2.2?
whats the best website to get WI info on local events?
Old 02-16-2012 | 11:19 PM
  #4155
AaronJ's Avatar
Matt, just google Milwaukee SCCA. Most of their events happen at Miller Park. Or if you want something closer to home for you, Fox Valley SCC (google fvscc) they do some at Shawano (spelling?). Since I live in Oshkosh now I want to hit atleast one up at Shawano and one down at Miller Park. Idk what your mods are exactly, I don't remember, but there are links from the Milwaukee SCCA page to figure out what class you are (there is a little yes/no spread sheet that helped me out a lot). Its fun. I'm just dissapointed that when I was on the formula SAE team at UW-P, we never had a car running long enough to get it to an autox event just for fun. I imagine it would performed really well since that's what it was designed to do. Once you PPE guys get that saturn done, you should race it
Old 02-16-2012 | 11:23 PM
  #4156
AaronJ's Avatar
So I'm gonna be there Saturday. Here's my question, I have Brembos (obviously) but do I need to change brake fluid? I really don't want to go through the hassle if I don't have to (I live in an apartment so I have to drive home to use either my parents garage or a buddy's garage ). My buddy with his Integra is coming on Saturday as well, but he's done a NSX brake swap and he still swapped to DOT 4 or ATE Blue or something like that.
Old 02-16-2012 | 11:51 PM
  #4157
padlock's Avatar
thanks for the quick run down, Ill look into it. (ive got a gut feeling ill be in a terrible class given my mods) oh well it will still be a fun time. me and two buddies actually plan on making it to shawno so you should let me know if you plan on making it down when the time comes.
n as far as PPE is concerned.. autox is going to happen with the saturn for sure once its done! it should be pretty damn quick considering stock its specs are (125hp and it weighs 2350lbs). now with the fresh rebuild on slightly higher compression, a totally gutted interior, and a/c delete id like to say we would be around the 135hp mark weighing somewhere around 2250ish so it should be fun. we are still deciding what to do to it this fall (regarding possible alternative fuels or even as complex as hybrid status)
Old 02-17-2012 | 12:03 AM
  #4158
ebristol's Avatar
I did a lapping event at Shawno and it was a blast. Most fun I have ever had in my car.
Old 02-17-2012 | 12:04 AM
  #4159
padlock's Avatar
^looks like a blast!
whats the reason for having your corner markers removed???
Old 02-17-2012 | 12:08 AM
  #4160
ebristol's Avatar
I had someone convert them to clear lens.
Old 02-17-2012 | 03:25 AM
  #4161
so DOT 4 wont hurt anything if i change it and just run that from now on?? or do I have to go back to DOT 3 after the event??
How easy would it be to upgrade my brakes to the SS/TC 's or if its a PITA/Expensive and then what would be a good choice for rotors/pads if I dont go with the T/C's
Old 02-17-2012 | 01:10 PM
  #4162
VapeWI's Avatar
My heat exchanger is in!!! Now who wants to help me install it? lol I guess it should be pretty easy but I really don't have access to any tools and not enough confidence and knowhow to trust myself lol. I offer beer, money, or fun!? lol Who would be able to help me out?
Old 02-17-2012 | 01:16 PM
  #4163
ebristol's Avatar
I could probably help you out. Your in Osh, right?
Which one did you get?
Old 02-17-2012 | 06:15 PM
  #4164
If you have the original fluid in your car you will want to change it. I am not sure what fluid is used with the brembo's so you might want to look into it.
You can run DOT 4 and it wont hurt but you have to flush the old stuff out first. Its cheaper to buy new pads and rotors then to swap over to the brembo's. My advice for brakes is go to Napa and buy their premium rotors (made with US steal not China steel) and run a minimum of HP+ pads. There have been some people that have run HPS's but they took it easy on the brakes.
Old 02-17-2012 | 06:20 PM
  #4165
VapeWI's Avatar
naw i'm in Milwaukee. I got a heat exchanger from a ford lightning that has been fabbed to work on the cobalt. I would just need to drill 4 holes into the bump cover for the brackets.
Old 02-17-2012 | 06:43 PM
  #4166
ahkeelyou's Avatar
anyone know a good tuner in wisconsin? i ordered a new vibrant header and downpipe and lookin to get a trifecta tune
Old 02-17-2012 | 07:00 PM
  #4167
VapeWI's Avatar
Mike can tune ya! Stardize I think his name is on here. I just got a trifecta tune in my car a few weeks ago.
Old 02-17-2012 | 07:02 PM
  #4168
ahkeelyou's Avatar
how ya like it?
Old 02-17-2012 | 07:16 PM
  #4169
VapeWI's Avatar
how ya like it?
Can't say that it added that much yet as I'm just a stock stage 2 atm with a CAI. But my fuel trims were really messed up from the CAI and it needed to be fixed. So just the fixing of the fuel trims was absolutely great. I did notice a bit much pull as now I can chirp 3rd but I have my winter wheels and tires on so IDK till I get my summer wheels back on. He didn't get it completely right at first and Mike came all the way back and had him adjust it. I think its pretty much perfect right now with the exception of a just a little bit that I think can be squeezed but, I also know that we are in the winter blend for the gas so that will also make a slight difference. Do you have a LSJ or LNF?
Old 02-17-2012 | 07:22 PM
  #4170
ahkeelyou's Avatar
neither i have a 2.4 na (automatic unfortunately) but i heard its a pretty safe reliable tune in that regard and i have an injen sri on right now so well see how it goes but thanks for the reference...where is he located?
Old 02-17-2012 | 09:07 PM
  #4171
VapeWI's Avatar
hes located where ever you are lol. He will come to you. But let him speak for himself I'm sure he'll see this eventually.
Old 02-17-2012 | 09:31 PM
  #4172
strazdice's Avatar
Hit me up
Old 02-17-2012 | 11:08 PM
  #4173
ahkeelyou's Avatar
Originally Posted by strazdice
Hit me up
i will fer sure once i get my parts on
Old 02-17-2012 | 11:43 PM
  #4174
padlock's Avatar
Hit me up
or me... if its closer... lol doubtful though
Old 02-19-2012 | 04:12 PM
  #4175
ebristol's Avatar
Or me. I am close to Green Bay.
Trifecta tunes are pretty basic. No matter who you get one from, it will work great.
Quick Reply: Wisconsin Thread (Team Rev & Others)
