Wisconsin Thread (Team Rev & Others)
#4435
Here is the exhaust guys and gals. Matt did an amazing job and I would recommend him to anyone. Everything sounds great and I got an avg of 33mpg's on the way home! I do need to make the exhaust a little more secure as it moves around on bumps a bit but other than that I am happy as a pig in ****!
#4438
Vape / Marks new exhaust - YouTube
Here it is. sorry it took so long lol! through the stock header and cat.
#4440
Believe it or not he'd be more likely to get pulled over for his tint, than the exhaust down here. Unless you doing something out of the norm they shouldn't have a problem. If it where say 5 years ago it be a different story. That's just from what I've noticed. I've never had a problem with mine. And mine thrumps that for loudness by a vary large margin.
#4442
Holy ****!! my strut worked itself undone from the ******* bolt on my passenger side. While I was driving! I barely made it home. Now I need to see if the strut is ok and replace the bolts. Only shitty thing is finding someone to compress springs...etc bla bla. fml
#4443
Alright guys and gals. I got ******* lucky! The strut tower just undid it self from the bolt. I didn't even need the spring compressor's I went to borrow. We just jacked the car up, took the tire off. Then put the jack under the hub and jacked it right back into place. Then tighten the bolt the way it should be. ******* happy nothing bad happened. Thanks to Matt(overboostedss) for all the help.
#4445
#4447
See that raspiness goes away then it sounds nice and tame unless I really womp on it. And that was the same amount of throttle I gave it in the first one.
#4448
I dont have a tig welder at home but I do have the option to tack the system up on the car and take it to work and tig weld it there. Ive got my mig and that always works fine for me. Ive lost track of how many exhaust systems ive made and they all work great. as far as the bends go if you wanna order 2 90's and a 180 that'll work fine. usually i cut 22 degree and 45 degree wedges and weld them together. makes really nice bends that I can make super tight if they need to be or gradual. either way. Im not in this for the money. I enjoy custom fab work and if you guys can get a nice exhaust for a few bucks rather that a few hundred that will make both of us happy cuz i like keeping money in my pocket and im sure you guys do to.
#4450
I need my downpipe redone badly. The flexpipe is shot, the pipes arent straight where it connects to the exhaust, the bends arent tight enough off the turbine housing so its too close to the trans mount and heatercore lines.
