Any one in Delaware out there
Old 06-08-2010, 10:08 AM
  #19201
rallycobalt06's Avatar
actually i was watching this new show called Top Shot.... they bring in all these expert shooters and see who's the best. they were using all these old rifles from WWI, WWII, Vietnam & Korean War.
then Pawn Stars came on, i find it to be a good show, the old man is hilarious.
Old 06-08-2010, 10:13 AM
  #19202
Capo's Freak's Avatar
Pawn Stars is effing hilarous...I haz DVR set for it.
Old 06-08-2010, 10:16 AM
  #19203
wantedSS/TC's Avatar
Chumley = the brain of a jelly fish.
Old 06-08-2010, 10:19 AM
  #19204
Chumlee
the show i saw last night was when the dad had his son & Chumlee do head to head in a physical competition. he created an obsticle (sp) course for them to go to and the Old Man said "this is going to be funnier than hell"
i almost lost it!
Old 06-08-2010, 10:38 AM
  #19205
yeah, they were fat and slow. surprisingly chumley won too!
This guy:
http://philadelphia.craigslist.org/cto/1777682210.html
accord for evo, STRAIGHT UP.
i havea 1996 honda accord
180.000miles
auto
red
fast
vtec
good inspection til 7/10
no exhaust
keeps up with most single cam
looking to trade for a mitsubishi evo 8
looking for straight trade. pefer a blue one but
if not then another color plus cash on your end for trade
needs to have low miles
no joy rides my car is mint.. so should your's!
Old 06-08-2010, 10:40 AM
  #19206
it's that vtak yo!
Old 06-08-2010, 10:44 AM
  #19207
CudaJoe's Avatar
Originally Posted by wantedSS/TC
use t-clamps
/ worries
yes sir!, the ZZP pipe comes with T-bolt clamps. And it reuses the stock couplers which also use T-bolt clamps. So I gots T-bolts clamps all around! I am worried that they aren't tight enough though, I tightened till my wrists were bleeding. How tight do these clamps have to be?
Old 06-08-2010, 10:45 AM
  #19208
tight like a tiger!
Old 06-08-2010, 10:46 AM
  #19209
You don't want to over-tighten them as it can be just as bad. just tighten them til you have to use your shoulder to push it again, then turn it 1 more half turn and you'll be good.
I've ran 30psi through my turbo and the clamps have held and NEVER popped. I keep a 7/16 and 10" wrench with me in the car just in case though. Haven't needed them yet.
Old 06-08-2010, 10:53 AM
  #19210
CudaJoe's Avatar
lol, I keep all my tools in the car. I have enough tools to completely strip this car down if need be. 7/16's was a surprise to me though, everything else is metric on the car.
Did you guys see all the info i've posted about the K&N intake in the tech/ general discussion threads? I've made a critical discovery reguarding the positioning of the filter on the intake.
  #19211
yup. caught me off guard too!!!
nah, got a link??
Old 06-08-2010, 11:12 AM
  #19212
CudaJoe's Avatar
https://www.cobaltss.net/forums/show...198192&page=28
this is when I got it, look at the craftsmenship, lol.
https://www.cobaltss.net/forums/show...198192&page=31
this is when I made my pivital (sp) discovery!
https://www.cobaltss.net/forums/show...198192&page=32
here Jarhead, trys messing with filter rotation and realizes I was on to something.
https://www.cobaltss.net/forums/show...198192&page=33
and me showing the newbs what I meant by clock position.
Old 06-08-2010, 11:25 AM
  #19213
BlackCobalt707's Avatar
screw t-clamps, constant torque clamps are the ****
Old 06-08-2010, 11:26 AM
  #19214
so hows that boost leak?
Old 06-08-2010, 11:29 AM
  #19215
CudaJoe's Avatar
ooooo that was good, lol.
Old 06-08-2010, 11:32 AM
  #19216
im not sure if its even a boost leak :P
but the constant torque clamps hold like a ****, i had t bolt clamps and the pipes kept blowing off
Old 06-08-2010, 11:36 AM
  #19217
Token..... you've got a few options....
option #1: try to sell the car as is with all the crap on it and let it become someone else's problem.
option #2: put it back to n/a, keep it as a decent DD & build the Civic
option #3: drive the car off a cliff, perferably on 896 in Lancaster, PA
they kept blowing off because the pipes weren't rolled at the ends!
:facepalm:
Last edited by rallycobalt06; 06-08-2010 at 11:36 AM. Reason: Automerged Doublepost
Old 06-08-2010, 11:44 AM
  #19218
im not sellin the car, im not putting back to stock, and im not runnin it off a cliff.
and my pipes arent rolled still, and the constant torque clamps are holding tight
what can i use to safely remove the paint on my lights without damaging the plastic?
Last edited by BlackCobalt707; 06-08-2010 at 11:44 AM. Reason: Automerged Doublepost
Old 06-08-2010, 12:01 PM
  #19219
CudaJoe's Avatar
wet sand them with 1000 grit, then with 1500 grit, then with 2000 grit. finish up with Rain-X headlight restoration kit which comes with 3 polishing pads, lubricant, and a sealant to protect from pitting on your sanded headlights.
If its really bad start wet sanding with 800grit. Use a mixture of soapy water for wet sanding or the lubricant that comes in the restoration kit.
Old 06-08-2010, 12:09 PM
  #19220
didn't you put super glue on them?
he spray painted his tail lights black instead of getting VHT spray tint.
Last edited by rallycobalt06; 06-08-2010 at 12:09 PM. Reason: Automerged Doublepost
Old 06-08-2010, 12:32 PM
  #19221
BlackSS185's Avatar
o wow super glue, and goof off may work on your tail lights or graffiti remover.....
Old 06-08-2010, 02:06 PM
  #19222
CudaJoe's Avatar
ahhh... okay, I would first try taking the paint off the tail lights with a paint thinner/ Isopropyl alcohol/ nail polish remover/ acetone. Once you get most of it off, and there is still black pitted in the plastic, do the wet sand thing, they will look close to new (well as close as you can get)
Old 06-08-2010, 03:56 PM
  #19223
let the taillights sit in turpentine for 8 hours!
Old 06-08-2010, 03:57 PM
  #19224
wow, noone is givin me a break today, first i get called a ricer because i drive a 4 cylinder and then i get it from here. and no i didnt use super glue, i used hi-temp rtv, big difference. and i used it for a little bit then took it off cause i didnt want any comin off and possibly getting sucked into my engine. and i spray painted cause i wasnt familiar with vht. now that im familiar with it, when i run thru inspection im using it. and did you know they arent failing people anymore for gauge pods?
finally, someone on here with sense, i thank you kind sir. everyone else can go suck a dick lol
Old 06-08-2010, 04:44 PM
  #19225
well i had a 3 gauge pod 2 years ago, they failed me for it. i put my stock pillar back in, they said something about it, i told they moron that it was a stock pillar. old man didn't know what to say.
oh well, i don't like the 3 gauge pillar pod look anyways.
Quick Reply: Any one in Delaware out there
