Any one in Delaware out there
i dont wanna crack them open myself, i did it to my integra and it came out fine but these cobalt are pain in the dick
nope, run them as piping. i want minimal pipes lol. i just talked to RPM, i might just have them do it and have them weld most of the pipes together or something. eliminate any chances of boost leak
buy the ******* universal kit, it'll come with couplers & clamps. it'll be all you need and won't look ******* ****** rigged like your last setup. don't run silicone hosing as piping, seriously, that's gay.
don't go to RPM either, go to VEROCIOUS Motorsports if you're going to have someone make you custom piping. both shops will cost you an arm & a leg to do the work, but Verocious is the best.
I've ran 30lbs, 22 lbs, 25 lbs, 15 lbs, 0 lbs through my piping held with couplers and t-bolts.
why the hell would you want them welded together? waste of money!
he's trying to spend money he doesn't have
dude, if you use the right couplers & clamps, there won't be any leaks. especially if the ends of each pipe is rolled.
Last edited by rallycobalt06; 07-19-2010 at 03:53 PM. Reason: Automerged Doublepost
look, ill just put it like this. im at my wits end with this POS. im going to do what i gotta do to make sure no ****** air escapes and it all stays in the pipes
