Any one in Delaware out there
well fellaz, i have a dead cylinder, did a compression test and #1 150, #2 150, #3 155, #4 0.....and after askin people on here they said if i have 0 compression it sounds like a hole in the cylinder. what do yal think caused the problem? stock 10:1 compression? if so then im going to get 8.9:1. ima take the head off this weekend probably and then i can see what exactly happened
well, 3 out of 4 ain't bad..... oh wait...........
you should have some compression in that #4.... it wouldn't be "0"
i know from experience. redo the test, have a professional do it.
Ill test it after work again. My car is barely driveable so a shop is out of the question. I did it correctly, made sure the tool was fully threaded in just as I did on the other 3
when they did a compression test on my car when i blew my #4 cylinder.... it was 140, 140, 135, 50
get it? hope so. no limp that piece of **** to a shop and have it done right for once. if you're just going to continue to go cheap on the thing, it'll never run for more than a couple weeks, especially with you trying to race everyone (i know everything).
