BCP Performance
well results.... my car was having a little misfire problem, figured it out it's all fixed but it's not in the vid.
Rob's got a bit milder version than I got though.
video might not be ready yet.
http://videos.streetfire.net/video/c...ff012776da.htm
Paul thats the same thing that happened to me. I deleted the .cfg or whatever and when you open the program itll ask you for your application key. Once you put it itll be fine. The problem is when you try to flash the car without the key in the ignition it forgets the car it was talking to or something. and it kind of freezes the Box. You have to reset it by renaming it. Its done it to me twice already but that trick helped me fix it.
yeah I got it working... never had the flash without a key thing (I know it doesn't work) just switching from 2.0 - 2.4 and back again it freezes it out.
ok something got f'd up with the vid... I'm uploading a new version
ok new link for full vid...
give it a few minutes to optimize
http://videos.streetfire.net/video/7...ff01552c3a.htm
Last edited by 06blackg85ss; 03-28-2007 at 08:41 PM. Reason: Automerged Doublepost
paul i got the pics...uploading now!
before:
http://www.imagewoof.com/view_image/...obaltss008.jpg
http://www.imagewoof.com/view_image/...obaltss003.jpg
after:
http://www.imagewoof.com/view_image/...obaltss007.jpg
o yeah anyone whos stock like me, BCP's superstock tune rocks. id recommend for anyone who has a fairly stock ss/sc
oo yeah depending on what part of the video he shows, those stop signs that i blow are fake stop signs. lol
before:
after:
Last edited by 95cobra68camaro; 03-28-2007 at 11:07 PM. Reason: Automerged Doublepost
thanks for posting up the pics man.... I"m going to finish mine up this weekend, smooth everything out on the outlet, and port the inlet and polish it all nice like.
the stop signs with the white border are optional..... lol
Last edited by 06blackg85ss; 03-29-2007 at 07:27 AM. Reason: Automerged Doublepost
yeah man.. I was watching the vid last night... Thing screams. I might need to borrow those bits from you this weekend, I want to enlarge and smooth out the inlet a bit. I'll hopefully get some compare logs up today at some point if I ever get a chance to do a full pull. Show before and After boost logs..
#36
"that things sounds like a banshee swooping threw the sky lol"
hahahahaha. I didnt even think you could hear me exhaust but its pretty noticeable in thevid. Paul u can have all 3 of those bits if you want them. I might see ya fri. nite.
Anyone planning on porting their blower, SK speed (my job) sells killer bits all you'd need is 2 bits a 3/8" for the corners and a 1/2" to open up. They are meant for aluminum and are self cleaning. The entire job of porting my blower was done in less then an hour of everything, removal/port/clean/install thanks to those killer carbide bits. It took me and paul a total of 2-1/2 hrs total from when he came over to the video u see.
#41
well as for the meth,,,, kinks and tune are already done and waiting to go back in... Might be the death of the motor... but that's what the spare one is there for. I don't think I'll be running as an aggressive of a tune as I had with my first setup. maybe only 22 degrees on pump for the street... bump it to @26 for the track only..
run after porting
before porting... (mind you only outlet so far)
BTW don't mind the KR... I was seeing how much timing I could push. backed it off since then. I can't wait to get my meth. Also check out the difference in IAT2 at full boost
run after porting
Last edited by 06blackg85ss; 03-29-2007 at 07:23 PM. Reason: Automerged Doublepost
#44
I"ll be finishing it up saturday porting and polishing the inlet on it, so far just did the outlet, plus I need to even it out a bit more too. More details to come.
on another note, I found out RIPP is dropping the cobalt project, didn't even ******* say anything to me either.. OH well it still is going on , just gonna have to finish it myself. But damn at least say something to me, I had to find out from Darksun.
Last edited by 06blackg85ss; 03-30-2007 at 07:34 AM. Reason: Automerged Doublepost
#46
#48
he;'s still on a 3" pulley.. BCP bad-ass tune.. and STOCK INJECTORS (I'm putting in at least 42's man whether you like it or not)... I want to see the vids/// stupid work computer.
but 2k5sssc.... I"m guessing the new config file worked good for you?
#50
I know man.... gotta take a look at it... didn't get to log after the tune.. so god only know's what she's doin..
and yeah sean... it sucks.. but what the hell.. my friend is moving back up to NY, he has a flowbench, and another friend just opened a shop up in mineola. (he's doing my cage and manifold) so it will get done one way or another.
