View Poll Results: What to sticky?????
Gym, Tan, Long Island
69
14.08%
Fist pump
421
85.92%
Voters: 490. You may not vote on this poll
Calling all Cobalts on L.I.
Old 04-21-2014, 10:18 AM
  #15976
jonathan923's Avatar
so both cars yours and ants in completely dialed in? and you guys missed a badass meet it wasent even cold bro i was wearing a reg Tshirt lol
Old 04-21-2014, 02:52 PM
  #15977
06blackg85ss's Avatar
we didn't get done until well after 1am lol. anthony was lucky I was drinking.
wish I could come down for the dyno next weekend, but I"m booked on weekends until after memorial day weekend. better have some one video that **** for me
Old 04-21-2014, 02:56 PM
  #15978
lol damm i should have been there i could had help with the drinking haha. am glad both cars are running 100%
cant wait till we start messing with the srt4
Old 04-21-2014, 03:31 PM
  #15979
lol probably coulda used the help.
and yeah man, hopefully hpt gets this thing going soon. was hoping to possibly have something this week
Old 04-21-2014, 03:55 PM
  #15980
yellowsupercharged06's Avatar
ill def make sure its on video lmao
if i dont hit 280 im guna look like this
Old 04-21-2014, 03:57 PM
  #15981
and ill be like this
Old 04-21-2014, 06:39 PM
  #15982
mezzanno's Avatar
Big shout out to Paul for this weekend !!! had a great time chillin and getting Ant's car dialed in.
Dyno day time .... Paul what ya think ?
in my opinion his car is far from dialed in, theres at least 50 more hp if he's willing to take the necessary steps.
Old 04-21-2014, 07:13 PM
  #15983
You dirty little meth addict lol
Old 04-21-2014, 07:41 PM
  #15984
advise's Avatar
Im willing lol give me a month
Idk if we got 50 left in her
But shes dialed in great up top
Small idle timing adjustments and ill be happy
Meth in large amounts on the way
I like mikes no ***** giving additude
Ill make power or blow up I dont care
If it breaks build it stronger
Old 04-21-2014, 07:57 PM
  #15985
Hahahha no **** given ... **** knock retard table lmao
That **** was hilarious
Old 04-21-2014, 10:44 PM
  #15986
mezzanno's Avatar
no methanol just makes power, at the proper air fuel ratio methanol releases 20% more btu of energy than gas and 15% more than e85, if we set you up with with a heavy dose, say an m15 and an m10 on a 250 psi pump that would be around 200lbs an hour of meth being sprayed at full tilt, now I didn't bother to do the calculations but I would guess that would make up for at least 30 percent of your fueling. if that's the case just on the way meth burns alone you would gain 5% more power.
now we have to look at how an engine makes power. The more oxygen we get in with proper afr the more power we have. how do we get more oxygen, A BIG V8... but that's out for you because you got a shitty cobalt (and yes I can say that because I owned 2, and they broke a lot). but seriously now how do we get more oxygen in. first lets look at da.
density altitude: or d.a. for short is the amount of oxygen in a give volume of air. Three things can affect this, pressure, temperature, and water vapor in the air or humidity.
first lets start with pressure, standard atmospheric pressure weighs 14.7 pounds in a space of one square inch in your x and y planes and roughly 20 miles in your z plane. this is what we normally have to work with in a natural aspirated engine. to make more power with this we can upgrade the exhaust, air intake, or better yet change the heads and the cam. This will help make more power and you did all this which is good. now to make even more power you supercharged your engine with a roots blower. we all know roots make 90% plus boost as fast as your foot hits the floor. this is good, cars are snappy and take off but roots blowers compress air in the intake manifold and this creates turbulence and that heats the pressurized air very much so. this is very bad, but the good thing is say if you run 29 psi of boost you essentially triple the size of your engine while in boost. so far you have this covered.
temperature, for every 10 degree drop in air temps you pick up 1.11% horsepower. Im not pulling this out of my ass this is a fact. this is why records are set at the track in October and November. now in your case you have roughly 170 degree iat2's which is bad. all that air you pressurized has very loose oxygen content. you want your oxygen dense. to do that we need to get the heat out of the charge. INSERT METH INJECTION when you add meth injection pre blower so It can chill the air charge as it's getting compressed not only will you have more pressurized air but the oxygen content will be dense. Now to make this happen with a roots blower you have to spray a MAN SIZE SHOT. no ***** m5 nozzle setup on a 100 psi pump. That's childs play. see paragraph one for MAN SIZE SHOT
humidity or water vapor. unfortunately we can not change the humidity in the air on a given day, it is what it is. the higher the humidity or water vapor in the air and subsequently in the charge entering our engine the less power we will make. This is bad but we can't control it. What we can control however is when using a meth injection kit is NOT ADDING ANY WATER TO THE ******* MIX AS THIS WILL KILL POWER.
now some quick math, meth as a fuel sprayed in heavy volume will net at least 5 percent more power. dropping your iat2's from 170 to say 50 should net 13% more power and on top of that with the extra octane afforded by the meth you can add ignition timing and quite possible drop another pulley size.
in conclusion, spray meth kids, lots of meth, and only meth, water sucks it really really sucks.
Old 04-21-2014, 11:08 PM
  #15987
advise's Avatar
Wish I never sold mine
Now what to get
Progressive system?
Alcohol injection or devils own
Old 04-22-2014, 07:04 AM
  #15988
alky control I think is what mike is running, one of the few kits setup for running 100% meth.
and mike does lots and lots of research, and for some reason actually cares about making you cobalt fast lol.
I'd listen to the man.
of course this also means more work for me on the tuning side lol.
Old 04-22-2014, 08:49 AM
  #15989
mezzanno's Avatar
Get alky control. Its the best and is meant to run 100 percent meth. Plus it comes with nice braided steel lines and a good high pressure pump. It cost a bit more money than the other kits but is well worth it
Old 04-22-2014, 09:29 AM
  #15990
so if ant sprays all this meth, do you think he can ditch the mini afc ?
as long as he beats the evo lmao
Old 04-22-2014, 09:37 AM
  #15991
one heck of meth class here
Old 04-22-2014, 10:43 AM
  #15992
advise's Avatar
Ill still need the mini afc
Probably even more because of could dense air
Old 04-22-2014, 11:00 AM
  #15993
mezzanno's Avatar
No he will still need it. Maf readings wouldnt change at all if the nozzles were placed after the maf sensor.
Old 04-22-2014, 11:04 AM
  #15994
ahh gotcha .... ant you should def investigate that gay hrtz hiccup in the middle of the pull .. tell zzp its broken lmao
Old 04-22-2014, 11:15 AM
  #15995
yup still need the mini afc. and yeah it's a wierd fall out there, not sure what's causing that, everything else is opretty much perfect cept that 800rpm strangeness
Old 04-22-2014, 01:14 PM
  #15996
advise's Avatar
Ill look into
Not to worried
It just gives that mid range lean pull I like lol
Old 04-22-2014, 01:22 PM
  #15997
Originally Posted by advise
Ill look into
Not to worried
quit hitting bumps in the road and that kr wont come in and u can keep all your timing to redline lmao
Old 04-22-2014, 02:57 PM
  #15998
mezzanno's Avatar
just reduce the attack rate on the knock sensor, bumpy roads won't be a problem anymore
Old 04-22-2014, 04:56 PM
  #15999
advise's Avatar
Saturday is judgement day
Going on the rollers
Previous dyno of 328/282 on stock motor
Tvs 2.7 pulley about 26psi weather dependent
e85
full bolt ons And full cooling mods (besides meth)
New stuff
Cnc m2 race head to bcp specs
.5mm o.s intake valves
.5mm o.s iconel exhaust valves
75# dual coil springs
Stage 2 s/c cams
Neutral balance shafts
Arp head studs
Id1000s
Mini afc
8k Redline
And a solid tune thanks to paul
Old 04-22-2014, 06:49 PM
  #16000
mezzanno's Avatar
where did you make peak power on your first dyno run
Quick Reply: Calling all Cobalts on L.I.
