View Poll Results: What to sticky?????
Gym, Tan, Long Island
69
14.08%
Fist pump
421
85.92%
Voters: 490. You may not vote on this poll
Calling all Cobalts on L.I.
Old 09-04-2014, 10:28 AM
  #16401
yellowsupercharged06's Avatar
2015 wrangler lol its posted above lol
that wrangler cost a pretty penny they aint cheap.
Anyone want to/ know how to rebuilt a F35 ? ill pay $$$$$$
Old 09-04-2014, 10:46 AM
  #16402
jonathan923's Avatar
oh thats right lol i know how to take an f35 apart just go turbo
Old 09-04-2014, 03:53 PM
  #16403
1slobalt12's Avatar
Ordered a 2015 Jeep Wrangler 2 door in a new color called Tank but i have around 2 month until it arrives
Old 09-04-2014, 04:42 PM
  #16404
thats awesome man! congrats!!
Old 09-04-2014, 08:52 PM
  #16405
1slobalt12's Avatar
Thanks,
Selling this car is a bitch though.
Had a kid and his dad come test drive it. The kids dad was picking things out about the car that there wasn't even issues with but obviously he didn't know much about cars and wouldn't listen to my trying to explain it to him
Old 09-04-2014, 10:52 PM
  #16406
Was he saying the suspension was shot cuz of the lowness on the coils lmao ??
I found a pic on my comp of my and ur car at pilgrim state lol ill post it up for memory sake
Old 09-05-2014, 10:08 AM
  #16407
anything going on this weekend?
Old 09-05-2014, 10:32 AM
  #16408
im changing my rear brakes lmao
Old 09-05-2014, 10:34 AM
  #16409
when is that head going in?
Old 09-05-2014, 12:49 PM
  #16410
at this rate probably a billion years from now.
im too much of a bitch to rip it apart.
Old 09-08-2014, 09:41 AM
  #16411
mernin!
Old 09-08-2014, 11:19 AM
  #16412
06blackg85ss's Avatar
don;t be a puss, it aint that bad. d/l the gm build book, walks you through pretty much step by step. it's not as bad as it looks honestly
Old 09-08-2014, 12:31 PM
  #16413
ive got that and the haynes repair man. & stages how-to lol
Old 09-08-2014, 06:44 PM
  #16414
so your good to go then. just read those books over and over.
Old 09-08-2014, 10:47 PM
  #16415
Yeah i have been ill do it one day
Old 09-12-2014, 10:06 AM
  #16416
Paul ... i need your wisdom.
What is needed to make the F23 work on an LSJ ??
Old 09-12-2014, 11:13 AM
  #16417
f23 shift cables
f23 front trans mount
f23 driverside trans mount
ss 2.4 na axles
and a little grinding on the case by where it goes under the thermostat housing
also may need to use the f23 slave cylinder (we did on chris's car) but you should be able to use the lsj one but would have to get a braided clutch line as the fitting points the opposite direction then the f35
think chris spent about $700-800 for everything including the trans
Old 09-12-2014, 12:50 PM
  #16418
thats mint thanks .... i read you need to keep the F23 TOB/slave
LSJ clutch/flywheel will work with the spacer ?
how about the LSD ? phantom grip any good ?
arent the early gen hhr non ss the best gears 4.17 final drive
Old 09-12-2014, 08:46 PM
  #16419
Clutch is fine no spacer needed. Chris has his exedy hyper single with a F23 tob.
As for lsd I have no experience with phantom grip but the team green one works good so far
Old 09-14-2014, 09:17 AM
  #16420
How about the knuckles ? Does the 2.4 use diff than the LSJ?
Ever rip one apart and rebuild it ?
Old 09-16-2014, 11:12 AM
  #16421
same hub splines no issue there.
and chris pulled his apart. apparently it is a very easy transmission to work on.
Old 09-16-2014, 11:24 AM
  #16422
so the input splines into the trans are the difference and im sure shaft diameter is smaller.
your cooling apparatus looks promising. ....
Old 09-16-2014, 11:27 AM
  #16423
yeah lsj axles will not work unless you get the half shaft turned down and resplined. still have to you 2.4 ssna driverside axle.
and so far results are pretty damn good. I just need to swap 2 hoses as I have it running the wrong way through the heat exchangers.... shouldn't be drinking when doing the detail stuff lol
Old 09-17-2014, 09:44 AM
  #16424
i may need to invest in the 2.2/3.0 w.e revision it is on when it is final lmao
Old 09-17-2014, 11:12 AM
  #16425
so far it's pretty promising, best iat's I've seen on any setup I've previously tested (well beside the turbo lol)
and looks like I'll be testing it with a tvs come sunday if a certain person can wake up in the morning lol.
Quick Reply: Calling all Cobalts on L.I.
