Turbo Ss Conversion Progress
Old 12-10-2007, 09:38 PM
  #51
chevysalesman614's Avatar
Originally Posted by 06blackg85ss
Unfortunately I can't weld, so I can't redo my piping at the moment.
i can. and i'm not that far from you. i went to pennco tech for autobody. mig, tig, w/e. (p.s. beer is an acceptable payment to me )
Old 12-10-2007, 09:39 PM
  #52
pimpnwink's Avatar
im subscribed at the moment im contemplating turbo kit or saving money toward the 2009 camaro. Decisions Decisions. For a second i was already set on the camaro not anymore lol.
Old 12-10-2007, 09:58 PM
  #53
06blackg85ss's Avatar
that sounds like a plan man. If anything we could use my friends shop over here by me, he has everything for metal fab work
Old 12-10-2007, 10:12 PM
  #54
Asphalt Assault's Avatar
If I cant get rid of my car, if I can find a LSD in a transmission, put in a aftermarket clutch, well then I may just get into this.....LOL.
Old 12-11-2007, 12:06 AM
  #55
06black's Avatar
Originally Posted by sneaky
subscribed. although I have seen bryans setup, I am weary of it up holding up. Bryan, darren still tuning your car?
no you havent mike, you've seen the old one.
Originally Posted by JANNETTYRACING
35R won't fit and is far too big, not happy till 30+ psi and too slow too spool on a 2.0.
The heads flow more than you think, we are looking at cams though.
But at the same time we want to know what we can do with the stock cams.
I am told 450 wheel is doable by the experts, We will see.
it'll fit, its all in how you mount it.....
i know this because i dam near swapped to a 35r with a bit smaller hot side....but then PR building and over all lack of shaft speed for the compressor wheel come into play.....i'm sure you know this tho
i test fitted one on my car with much success but then settled for my precision unit (SC3061RS) and i dont think i could be happier
i had my head flowed and it'll JUSTTTTTT barely move the air needed for 400...but i see the cam being issue before then....and when i do cams i'll have the head done, why not!?
i agree with you on not wanting to re-grind the stockers due to a imperfect base circle but cam blanks for the LSJ head are fairly non-existent, even thro my many GM contacts i had no luck....
who knows tho, you might have that perfect contact for such a task.
the 272's in DJT's car (before it popped) came in around 6500ish and it was quite the ride!
the turbo was in full boost and it would push you in the seat again when the cam came in, lotta fun!!!
i think a more mild cam would be my route, something that'll flow less on the peak but more under the curve....
the game just continues with this car......its a game we'll never win! theres always the "next step"
GL!
Old 12-12-2007, 10:47 AM
  #56
Edubs's Avatar
Click...
Old 12-15-2007, 07:43 AM
  #57
skymynx's Avatar
so any updates from you guys
Old 12-15-2007, 08:12 AM
  #58
SlowBalt_06's Avatar
about the strength of the block didnt toyota rate the 2jz block at 400 hp or under..and those guys are making 800-900 on stock block
Old 12-15-2007, 08:23 AM
  #59
JANNETTYRACING's Avatar
The Cobalt Block is a styrefoam casting so it is very thin and light for Gas Mileage and efficient casting.
The clylinder walls are thin Cast iron which is brittle in a thin aluminum liner with an Open Deck so there is no support at the top of the cylinders.
Block savers have been tried and failed.
The new sleeves are all steel at the top 2 inches so they are 4 times stronger than stock.
The stock pistons are pretty weak also GM recommends changing them at 300 HP.
So Our stage 2 Turbo kit will include sleeving the block and forged pistons.
Old 12-15-2007, 08:32 AM
  #60
what pistions do you prefer?and valve springs and valves nessesary? i will be turboing soon i am aiming for 325 that will be the max i will try to run....what did you guys do for the intake manifold..and congrats on the progess btw
Old 12-15-2007, 08:44 AM
  #61
I'm sorry man but I'm gonna have to argue with you there...
According to gm the stock cylinder liners are good to @600hp before they start distorting, as for the block, it is good to over 1000hp with proper prep, like billet crank, rods, pistons, and larger and longer head studs, along with the Bates strengthened cylinder liners.
the open deck design of the ecotec has proven to not be a weak point at all in these motors, unlike the honda motors (just an example of an open deck 4 banger) Gm even stated that converting to a solid deck was a waste and destroyed a few motors. Also I'm pretty sure the LSJ block was sand casted too just like the head is for higher strength which is why we don't need any modification of the head for higher boost, cept porting, cams, and valvetrain components. Already has built in re-enforcement unlike the L61 heads which need to be strengthened with studs placed into the roof of the combustion chambers to keep them from distorting.
Well anyway, I'm not really here to argue with you, Keep up the good work on the turbo setup. Looks like I"ll be finishing my car afterall since I already have eveything to build the motor anyway
Old 12-15-2007, 08:47 AM
  #62
06blackg85ss just wanted to say good work with your car...
Old 12-15-2007, 08:51 AM
  #63
Our plan with this motor will be JE pistons, Bates Sleeves, New vlaves, dual springs retainers, tensioner kit and a good valve job.
At 325 Wheel I would not touch the motor just our stage 1 turbo kit.
Old 12-15-2007, 08:53 AM
  #64
do you happen to have any pics of kit or progress
Old 12-15-2007, 09:24 AM
  #65
Your welcome to debate anything just get your facts straight.
The Supercharged 2.0 is definately a Foam Casting, Looks like one of those Foam coolers you pick up at Cumbys, nothing to argue about here, 400 crank HP is the limit.
The Supercharged 2.0 head is a sand casting, Saab Turbo cylinder head, good to 600 hp before porting acording to Bates.
The early 2003 down Ecotec 2.2 2.4 blocks were sand castings, maybe why GM used them on there Phase 3 program.
Oh by the way, the new Sleeves will be 3.500 bore, so some extra cubes are in the mix.
Just a few shots of the install.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Last edited by JANNETTYRACING; 12-15-2007 at 09:24 AM. Reason: Automerged Doublepost
Old 12-15-2007, 09:29 AM
  #66
thanks for the pics
Old 12-15-2007, 10:39 AM
  #67
very nice man.
yeah come to think of it. i was just looking at my other motor, it is lost foam cast... oh well. but as for the other info, I dunno I'm pushing over 400 crank with no ill effects at the moment, and soon to be more just to see what this baby can take (I already have another motor with a lightened, nitrided stock crank, Custom pauter billet rods, and diamond forged pistons at 9.5:1) just need to get the head finished and new cams and it should be together soon, now the dilema, what to do about are weak ass tranny's
Old 12-15-2007, 10:58 AM
  #68
LSX RWD S/C conversion
victory_red_SS's Avatar
very nice man.
Simple, RWD.
Old 12-15-2007, 11:14 AM
  #69
articzap's Avatar
You can make over 1000 hp on a stock 2JZ bottom end.
Old 12-15-2007, 11:27 AM
  #70
Originally Posted by victory_red_SS
Simple, RWD.
lol yeah oh so simple.. well i have a good tranny shop local that has done all my race automatics in my other cars, guess which route I'm going lol
Old 12-15-2007, 11:31 AM
  #71
Dyno schmyno!
what tells me is you got a rush of power and torgue at about 4000 rpm.
your intercept to GMS2 for torque 3600RPM and your well below that prior to the turbo spooling.
I am not slamming. it is a personal preference, design, and plans for use of the car that drives the over build. for street use and autocross I dont think this would do for most. for straightline? yeah it will get the job done pretty well.
THe proof will be when we see how these kits compare to an LNF GMS2 '08 which I think will be a truly nice matched setup to do autox really well and may not beat a kit car but will be the same or really close to the kit car. Time will tell.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
I must say so that is a clean and nice setup. great work with stock components making the throttle body plate.
Last edited by Asphalt Assault; 12-15-2007 at 11:31 AM. Reason: Automerged Doublepost
Old 12-15-2007, 01:31 PM
  #72
ptrblkz24's Avatar
So,thats the garrett kit?That **** looks awsome!!
Old 12-15-2007, 05:10 PM
  #73
06black's Avatar
i cant see how bates can clame that kinda power out of such a shitty flow number. the head doesn't flow whats needed to make 400-450whp let alone 600.
the head might be physically able to flow that but not with the stock intake and exhasut tracks.
(once again, not arguing with you, just stating my results for various tests)
and yea, i'm with you here. the block is most def a lost foam cast.
Old 12-19-2007, 11:24 AM
  #74
Some of the Hurtles we have overcome for the Cobalt SS Turbo conversion.
Fitting the GT3071R, which is only needed for Stage 2.
Supercharger Delete Plates, and Throttle body spacer.
Modification of the intercooler brackets to fit SS models
Fabrication of the charge pipes to the Cobalt SS 2.0.
Designing and mounting the maf in the charge pipe for proper readings.
Mounting the blow off valve.
Alternator rotation, mounting, routing of the belt and tensioner set up.
Tuning with blow through maf, for use of Blow off valve to Atmosphere.
Tuning with 60 lb injectors.
Supercharger inlet pressure sensor Check engine lite and Reduced power mode.
Other various Check engine lites.
Sourcing a company to make the charge pipes to our specs.
All this is done to the Stage 1 kit 325 and will come with GT2560RS.
Stage 2 will be Taking the engine above 325 wheel safely and effectively using the GT3071R, Sleeved block 3.500 Bore, Forged Pistons, Zero Balance shafts, High Temp Valves, dual springs, Titanium Retainers and a good valve job.
We should be up and running on the Dyno for Feb with Stage 2.
Old 12-19-2007, 11:27 AM
  #75
06black's Avatar
are you running the charge pipe under or over the block?
theres a perfect path under the car!
good luck guys!
Quick Reply: Turbo Ss Conversion Progress
