North Pacific WA and OR
Installing GMS1 next week
Old 10-21-2015 | 07:13 PM
E4Overlord's Avatar
Yosh! Because I'm a poor bastard but work at a Dealership it was easier for me to AR a GMS1 kit instead of buying HP Tuners and finding someone in my area to tune it. So with that said next week sometime I'll be getting the GMS1 kit installed and the reflash done. I only have a K&N CIA on my car at the moment and the Catless Downpipe from ZZP sitting in my garage. What kind of power gains should I be expecting and what boost numbers do you think I would be putting out.
2009 Cobalt SS/TC || 74k Miles
Old 10-21-2015 | 09:59 PM
slapbetcommissioner's Avatar
This is very easily searched for but il throw you a bone.
Make sure you buy the adapter harness from crate engine depot so they don't have to cut your harness. It will save you allot of issues down the road! Plus you can always go back to stock without problems.
I put down 282whp torque figure was skewed but based on averages I should have put down about 310-320wtq
My mods were k&n Sri 3"catted dp and gms1 at the time.
Also make sure the dealer uses the correct o rings as the ones that come on the sensor need to be changed. And a tab needs to be cut off on the lower sensor.
Old 10-21-2015 | 10:01 PM
Since no cars are on warranty any more I would just get the ZZP PCM tune and buy the sensors from crate engine depot. Better tune more power and you wouldn't need to buy hpt.
Old 10-21-2015 | 11:25 PM
Why not just buy the sensors from zzp they only sell the plug and play gms1 sensors?
Old 10-22-2015 | 09:00 AM
Or this
Old 10-23-2015 | 04:17 AM
HHRFrenchy's Avatar
I put down 286whp and 308wtq on my Stg1 with K&N SRI. Everywhere in Wa, I pretty much get 20psi. Occasionally, if conditions are right, it'll jump to about 22-23psi, and once I saw about 25-26psi, but 99/100 times, it boosts 20. Unfortunately, mods don't really do anything for factory or GMS1, as they have the learn down.
Old 10-23-2015 | 08:21 AM
Staged07SS's Avatar
Administrator
Administrator
GMS1 removes the learn down fyi.
Old 10-23-2015 | 09:05 AM
Or at least makes it a bit more lenient.
Gms1 cars with no bolt ons usually put down about 271-275whp 295-300wtq dp and k&n are usually good for about 10-15whp and wtq gain.
Old 10-23-2015 | 09:11 AM
HHRFrenchy's Avatar
Huh, Everything I've read said that STG1 still had the learndown.
Old 10-23-2015 | 09:16 AM
Staged07SS's Avatar
Administrator
Administrator
Everything I read said it's removed.
Also, read this below:
http://www.crateenginedepot.com/1921...70-P17741.aspx
Old 10-23-2015 | 10:37 AM
HHRFrenchy's Avatar
19212670 Cobalt, Solstice, HHR Stage Kit 19212670
I stand corrected...
Old 10-23-2015 | 11:30 AM
It's not that the learn down is entirely not present the engine tuning doesn't work that way. It just allows more leniency on the desired hp output so it doesn't lock it down when it senses more flow. It will still cut it off at some point. It just won't cut boost as early to make up for additional airflow.
jas09ss
09-26-2015 02:06 PM
jcarroll53
09-24-2015 08:43 PM
Superslowbaltt
09-24-2015 07:11 PM
dennis69
09-23-2015 03:56 PM
budah93
09-23-2015 03:26 PM
