Over The Top Performance Over The Top Performance is a supporting vendor.
Contacts: fast98 ; lsjwannabe
billet mounts installed
Old 02-25-2009 | 10:31 PM
Area47's Avatar
Rent me! per hour
i haven't pulled the ttr mount yet, so my vibrations felt will most likely go down.
17 and 18mm sockets needed.
torque on the mount to subframe is 40ft lbs on both of them
front mount is cake walk. two 17mm's and an 18mm and it falls out. i did this on a lift tonight in about 15 mins tops. with air tools.
rear one is a bit more technical to get out and swapped. not hard if you have enough ground clearance
really can't see the rear one too well it when it installed. you get the idea though.
dfco is less noticeable when hit. the vibes go away as engine rpm and speed increase. less rocking of the motor itself. i never had wheel hop issues aside from at the track when vht is involved. my tire pressure is set to 34 in the front, and 36 in the rear. did a 1-2 run after i got them in and still rolled smoke off the tires with ease. i can't use the two step to launch the car. meth nozzle is to big. have to drop the hammer at a higher rpm when i get bored enough to do it.
Old 02-25-2009 | 10:36 PM
HB_SS/TC's Avatar
I'll be needing this
Old 02-25-2009 | 10:40 PM
ItalianJoe1's Avatar
lawl at your review. All I read was "I have too much power, but you guys will probably enjoy these"
Old 02-25-2009 | 10:44 PM
ls1fbody's Avatar
Haz l33t wheelz.
meth nozzle is too big, lol
too bad i can't see the pictures.
does it still do that horrible bucking in first if you're not uber sensitive about the trottle?
Old 02-25-2009 | 10:47 PM
EatonTVS07's Avatar
i need some of these
i would like a ride porfavor
Old 02-25-2009 | 10:50 PM
Area47's Avatar
Rent me! per hour
415ml nozzle is a bit big when trying to roll into the throttle.
newp, no bucking. thats more of the driver input than anything else
Old 02-25-2009 | 10:52 PM
revhigh18's Avatar
how easy would it be to change the bushings on my tranny mounts
ls1fbody's Avatar
Haz l33t wheelz.
haha, i guess so.
10-4, just curious. wanted to see if i could be a little more lazy.
Old 02-25-2009 | 10:55 PM
car_guy_09's Avatar
::eh em::
I remember a certain tvs car promise a smoke show once these where installed
Old 02-25-2009 | 10:56 PM
Area47's Avatar
Rent me! per hour
pain in the dick actually
why would you need to change yours?
Originally Posted by car_guy_09
::eh em::
kind of hard to get a video by yourself
Old 02-25-2009 | 10:57 PM
EatonTVS07's Avatar
did you get the brakes too?
scott allen's Avatar
torque on the mount to subframe is 74ft lbs on both of them
whats the deal with the last mount you installed,whats up with the bracket,do you still use that bracket?
Old 02-25-2009 | 10:58 PM
EatonTVS07's Avatar
March 7th lets dooo ittt we'll get multiple angles
ls1fbody's Avatar
Haz l33t wheelz.
do what paul does, have your mailman get involved
Old 02-25-2009 | 10:59 PM
Steven Flit's Avatar
thanks for the short review Bryan
prolly pick these up in the near future.
Old 02-25-2009 | 11:00 PM
Black SS/SC 06's Avatar
Im curious to see how much of a difference these make. They look great. I dont have any wheel hop with my ttr mount.
Old 02-25-2009 | 11:04 PM
07blackg5's Avatar
Slobodan Milošević
so the tq spec for the subframe is 74, whats the spec for the tranny side? im swapping in my prothane bushings soon. thanks.
and great how to/show off thread
06 pursuit gt's Avatar
yes you still need that bracket. its what attaches it to the tranny. the toughest part of the whole install i found was getting the spacers to fit on the bracket with the new mount.
Old 02-25-2009 | 11:05 PM
Area47's Avatar
Rent me! per hour
that i would have to look up again when i get back to the shop tomorrow.
yes. you reuse the bracket on the backside.
Old 02-25-2009 | 11:08 PM
07blackg5's Avatar
Slobodan Milošević
thanks. can i bother you to shoot me a pm when you get the specs? thanks you
Old 02-25-2009 | 11:11 PM
rockkrawler628's Avatar
damn man your still on here?? good to see ya still here... i missed ss.net
Old 02-26-2009 | 01:12 AM
Where did ya go?
Old 02-26-2009 | 01:13 AM
restonSS's Avatar
^uranus (i had to say it)
Old 02-26-2009 | 01:16 PM
Area47's Avatar
Rent me! per hour
i stand behind this 100% on them working as intended. less power is lost when you get wide open, in a sense more is transfered to the tires instead of using it to rotate the engine. dfco entry and exit feeling is bog down is gone. shuddering when the clutch is popped is gone.
these mounts 110% work as they are designed to
Old 02-26-2009 | 01:27 PM
SS/SCking's Avatar
Are these the rotated mounts? if so how the space for the tvs? any clearance issues up top?
Quick Reply: billet mounts installed
