Over The Top Performance Over The Top Performance is a supporting vendor.
Contacts: fast98 ; lsjwannabe
billet mounts installed
Old 02-26-2009 | 01:33 PM
roadrage06's Avatar
Originally Posted by Area47
dfco is less noticeable when hit. the vibes go away as engine rpm and speed increase. less rocking of the motor itself. i never had wheel hop issues aside from at the track when vht is involved. my tire pressure is set to 34 in the front, and 36 in the rear. did a 1-2 run after i got them in and still rolled smoke off the tires with ease. i can't use the two step to launch the car. meth nozzle is to big. have to drop the hammer at a higher rpm when i get bored enough to do it.
Pardon, but could someone define "dfco" and "vht".
I ordered mine this morning. So excited to hear they are relatively easy to install.
Old 02-26-2009 | 01:40 PM
hungryhip-ccp's Avatar
i stand behind this 100% on them working as intended. less power is lost when you get wide open, in a sense more is transfered to the tires instead of using it to rotate the engine. dfco entry and exit feeling is bog down is gone. shuddering when the clutch is popped is gone.
these mounts 110% work as they are designed to
why would your decel fuel cut off be so rough to start off with? i never have noticed, wait wait i know what you mean now, your talking about say letting up in first and second and entering dfco, you get that horibble lunge foward followed by two clicks of the axels. then when you get back on it, it does the same thing? and you have to be super smooth to avoid this?
is that what you mean? that is much smoother now due to less engine travel/movement?
if so that alone is a big plus, and on a larger scale (DR's and VHT) its going to really shine...
Old 02-26-2009 | 01:41 PM
BriantheLion26's Avatar
Deceleration fuel cut off
VHT is what they put on the track to get grip.
Old 02-26-2009 | 01:42 PM
these mounts are looking better and better with each review i read, thanks bry bry.
roadrage06's Avatar
ah, now that makes sense. Well, now I'm even more excited, i get so embarrassed when i smack passengers heads off the dash in city stop and go traffic.
Old 02-26-2009 | 03:49 PM
N8s07SS's Avatar
subscribed for use when my mounts come in.
Old 02-26-2009 | 03:50 PM
Area47's Avatar
Rent me! per hour
less motor movement. results in less issues with engine movement. duh! smoother engagement and disengagement
did a 1-2 run in the rain. which lasted about 10 ft. zero hop. my car in first in the rain would hop. doesn't hop anymore
Old 02-26-2009 | 06:22 PM
08BlackSS/TC's Avatar
Torque Specs:
Front and Rear Trans Mount (thru bolts) - 74 ft/lbs
Front Transaxle Mount to Transaxle Bolts (2 bolts) - 66 ft/lbs (MUST BE TORQUED IN SEQUENCE BELOW)
-----> Top bolt, then bottom.
Rear Transaxle Mount to Subframe Bolts (3 bolts) - 44 ft/lbs
Old 02-26-2009 | 06:25 PM
scott allen's Avatar
should we use lock tite?
Old 02-26-2009 | 08:00 PM
Area47's Avatar
Rent me! per hour
nope. don't have too
Old 02-26-2009 | 08:12 PM
  #36
boostnss's Avatar
subscribed
Old 02-26-2009 | 09:37 PM
  #37
Area47's Avatar
Rent me! per hour
removed the TTR engine mount. vibrations dropped a lot. still just a hint of them, not like it was however.
same results on the street though
Old 02-26-2009 | 09:43 PM
  #38
boostnss's Avatar
does it matter if we leave the ttr motor mount in?
Old 02-26-2009 | 09:44 PM
  #39
SSdan's Avatar
Still waiting for smoke fest
Old 02-26-2009 | 09:48 PM
  #40
Black SS/SC 06's Avatar
You want to use the stock mount since its more flexible.
  #41
BlilBT's Avatar
Them are nice got to get me a set of those...along with a few other things this summer if all goes right!
Old 02-26-2009 | 09:50 PM
  #42
Area47's Avatar
Rent me! per hour
conn, you can leave it in and be fine. just vibrates more. since im the test monkey for these, i am just going off how they are intended to be used to get a real world result for the masses
Old 02-26-2009 | 09:54 PM
  #43
boostnss's Avatar
ok that works for me i dont mind the vibs plus i dont have the stock mount anymore
Old 02-28-2009 | 12:43 PM
  #44
Area47's Avatar
Rent me! per hour
snow report. everyone with stock mounts, or a ttr engine mount has this problem. 1st gear in the snow. let the clutch out. the car will hop.
with these mounts, this is gone. zero hop.
Old 03-01-2009 | 06:29 PM
  #45
Deathscythe's Avatar
I am glad they will work properly on lowered cars. You're the second or third I know of that have them installed on a lowered vehicle. I just have to find my stock mount now. Thanks.
Old 03-01-2009 | 06:54 PM
  #46
Rodimus_Prime's Avatar
THese are sounding better and better so the TTR upper mount can stay?
Old 03-01-2009 | 07:01 PM
  #47
did you get rid of your stocker?
Old 03-01-2009 | 07:15 PM
  #48
Area47's Avatar
Rent me! per hour
i took the ttr mount off, put the stocker back on. vibs are 90% gone. you can use it with the ttr upper. however, they are designed to be used with the stock side mounts.
Old 03-01-2009 | 07:22 PM
  #49
I know with the poly mounts, the resonating noise in the cabin seemed to be a lot worse than when I just had the hahn exhaust on. Is your cabin quieter now as well?
Old 03-01-2009 | 08:30 PM
  #50
rockkrawler628's Avatar
Originally Posted by ItalianJoe1
Where did ya go?
I left the forum for a lil while... I got rid of my cobalt and bought a stupid ass GMC Canyon... now I wanna get the new SS/TC and make it a project car...
Quick Reply: billet mounts installed
