Over The Top Performance Over The Top Performance is a supporting vendor.
Contacts: fast98 ; lsjwannabe
Billet Rotated Mounts
Old 03-24-2009 | 07:00 PM
  #251
beansirl's Avatar
hey josh just wondering if you have an update for me by chance?
Old 03-25-2009 | 05:38 PM
  #252
roadrage06's Avatar
Got them today:
OTTP makes another great product. Hopefully I can get them on this weekend and give a review.
Old 03-25-2009 | 07:29 PM
  #253
N8s07SS's Avatar
Originally Posted by fast98
Try loosening all you motor and trans mounts and then rock then engine back and forth by hand. It might not be setteled all the way and could be binding because of it.
I want to apologize for my previous post. It was totally my fault. I was an idiot and put the washers on either side of the new mount, not 2 to one side to make it on axis w/ the engine/car. (I just assumed, 2 washers, must need one on each side. I was in too much of a hurry to actually notice that the mount was crooked). I fixed that tonight and it really made a difference. I knew something had to be wrong, because there is no way that I would be the first person to point out that the vibes were actually WORSE with these than the polys. Just wanted to clarify so I go on record as being very satisfied w/ the product (SEE EDIT BELOW).
Shifts are much smoother now, no wheel hop on a hard launch. I was able to get hop by dropping the clutch at 2.5K RPMs (snow tires still on), but at anything below 2K, it was golden. And for people that really do care about the vibes, i'll put it like this: if stock ride is a 0 and polys are a 5, these mounts are right around a 1, and installing them incorrectly like i did is a 7.
EDIT: AFTER DOING SOME MORE TESTS AND GETTING THE SUMMER (STOCK) TIRES BACK ON, I'M NOT SO SURE ABOUT THESE ANYMORE. I'LL STAND BY THE SMOOTHER SHIFTS AND SOMEWHAT LESS VIBES, BUT I WAS ABLE TO GET HOP AS BAD AS IF I WAS ON THE STOCK MOUNTS. AM I MISSING SOMETHING? HOW CAN I BE THE ONLY ONE?
Old 03-25-2009 | 07:40 PM
  #254
Josh@ottp's Avatar
Originally Posted by N8s07SS
I want to apologize for my previous post. It was totally my fault. I was an idiot and put the washers on either side of the new mount, not 2 to one side to make it on axis w/ the engine/car. (I just assumed, 2 washers, must need one on each side. I was in too much of a hurry to actually notice that the mount was crooked). I fixed that tonight and it really made a difference. I knew something had to be wrong, because there is no way that I would be the first person to point out that the vibes were actually WORSE with these than the polys. Just wanted to clarify so I go on record as being very satisfied w/ the product.
Got pics? It is supposed to be one washer on each side.
Old 03-25-2009 | 07:53 PM
  #255
roadrage06's Avatar
Yes, please, pics. I'll have to look at Area's How-to again, but I definitely don't want to screw this up.
Old 03-25-2009 | 07:58 PM
  #256
stealthy1ss's Avatar
I got my today and I couldn't have asked for better timing. The car is currently on the rack with the tranny out of it waiting for the new exedy to be put in.
Old 03-25-2009 | 08:05 PM
  #257
ebristol's Avatar
Where are you having yours done? You got a hook up? lol
Old 03-25-2009 | 08:07 PM
  #258
scott allen's Avatar
do the mount s come with instructions?
Old 03-25-2009 | 08:11 PM
  #259
N8s07SS's Avatar
Hahahah, are you kidding me? Man I could have sworn that the mount looked slightly twisted with a washer on each side. The bottom-most bolt was even pretty hard to tighten the whole way. Well I guess it's possible that I just happened to jostle the engine around enough that it settled in place. I'll go take some pics and add them to this post. Well I'm guessing by my results that it really doesn't matter how the washers go, unless it affects the strength of the product.
Old 03-25-2009 | 08:19 PM
  #260
Josh@ottp's Avatar
Has your car been in an accident before?
Old 03-25-2009 | 08:27 PM
  #261
N8s07SS's Avatar
Nope. Here's the pics.
In that second one, you can really tell that it is in perfect alignment w/ the car. I'm telling you, when I had it installed with a washer on both sides, the mount looked like it was just slightly crooked. Even in the first one, if you can imagine the frame connection of the mount moving 1/4" (washer thickness) toward the passenger side, it would look misaligned. As long as you guys don't think it's an issue, I will probably leave it because it drives really nice, looks straight, and held up from those series of launches I did.
Old 03-25-2009 | 08:29 PM
  #262
damn they look nice do they tilt the moter forward or backwards?
Old 03-25-2009 | 08:31 PM
  #263
Josh@ottp's Avatar
Its definitely not supposed to be like that. I think all of your mounts might be twisted a little. I would suggest losening all of them and then tighten the front mount first the correct way.
Old 03-25-2009 | 08:39 PM
  #264
N8s07SS's Avatar
Um I think it is clockwise if you're looking at the driver's side of the car, but OTTP could answer that better than I. Whatever it does, it works.
Damn, ok I guess I'll do that tomorrow. See the thing is I installed it that way in the first place? I had all the mounts loosened and started w/ the front one. I'll try it again since that is the way you guys designed them. I guess I just don't understand how the motor can be twisted if all the mounts are fully tightened? Shouldn't they all pull it into proper alignment?
Old 03-25-2009 | 08:43 PM
  #265
Josh@ottp's Avatar
If you can't get it to line up the frame has to be bent.
Old 03-25-2009 | 08:57 PM
  #266
N8s07SS's Avatar
Like I said, I'll try again tomorrow or maybe this weekend and let you know. The car has never been in an accident, so if the frame is bent, it came from the factory that way. Did some searching and came across this quote from the Area47 thread in case anyone is interested:
Torque Specs:
Front and Rear Trans Mount (thru bolts) - 74 ft/lbs (good luck doing the rear one without air tools, you have about 2" of clearance and it's a long bolt)
Front Transaxle Mount to Transaxle Bolts (2 bolts) - 66 ft/lbs (MUST BE TORQUED IN SEQUENCE BELOW)
-----> Top bolt, then bottom.
Rear Transaxle Mount to Subframe Bolts (3 bolts) - 44 ft/lbs
Honestly the mounts don't really need instructions, they are very simple to install. I just had some trouble with alignment. I'm not fortunate enough to have access to a lift, so I was doing all this work on my back jacking up the engine millimeters at a time. I guess if I had to give advice, I would say loosen all 3 mounts, then tackle one mount at a time and tighten the upper engine mount back up last.
Old 03-26-2009 | 12:12 AM
  #267
schamsy's Avatar
Whew! Thank You! i was sweating things for a sec. I'm waiting until better weather/less road salt, because i have my Blizzaks on right now and dont launch or spin with them to save the threads.
Old 03-26-2009 | 07:41 PM
  #268
Bl4des's Avatar
just got my mounts on and they are so much better then my ttr solid mount and poly trans mounts the barely vib at all and i still get no wheel hop these are a must buy if you are ever planning on going to the track
Old 03-26-2009 | 07:43 PM
  #269
so no wheel hop at all, at any rpm?
Old 03-26-2009 | 07:46 PM
  #270
BLAZIN07SS's Avatar
I'm too JDM for you
i ordered these earlier this week. cant wait to get them
Old 03-26-2009 | 07:47 PM
  #271
Bl4des's Avatar
it is a little wet out but i just went out a spun my tires a little bit and it felt great cant wait for it to be dry out tho so i can test them a little more
Old 03-26-2009 | 08:06 PM
  #272
cool thats awesome cant wait till i get mine in.
Old 03-26-2009 | 09:29 PM
  #273
Mine are in the car along with the steering rack spacers and new clutch. I haven't drove the car yet because I need to bleed the clutch yet but I will be busy putting miles on the car breaking in the clutch and enjoying the mounts.
Old 03-27-2009 | 05:34 PM
  #274
schamsy's Avatar
Going to install these right now!
Old 03-27-2009 | 06:13 PM
  #275
INFE's Avatar
Im still waiting for mine OTT any idea when i should be getting my mounts??
Quick Reply: Billet Rotated Mounts
