Over The Top Performance Over The Top Performance is a supporting vendor.
Contacts: fast98 ; lsjwannabe
Billet Rotated Mounts
Old 03-27-2009 | 06:46 PM
  #276
Bl4des's Avatar
i just went out today to test them with it dry out and i did get a little wheel hop my solid motor mounts worked better i dont know if it is just because they aren't broken in yet but i still like them way better then the solid mounts because they barely give any vibs
Old 03-27-2009 | 06:50 PM
  #277
schamsy's Avatar
Stage 1 mount
I am going to give my honest unbiased opinion on the Stage 1 mount.
After installing the mount and starting the car up, I did notice slight vibrations. The vibs were small and they weren't enough to make any rattling noises. After i took the car off the ramps in reverse I did notice some vibs, but very minimal. After driving around for awhile I realized i could not feel any vibrations basically once I let the clutch out in 1st. At a 60 mph cruise there were no vibrations, only a small amount of cabin noise, but nothing annoying or loud at all. Well I got the mounts in and even though I had my winter tires on I did a 2k drop and I had no wheel hop. It was a good feeling to have a car with no wheel hop. The mount was very easy to install with few tools. I am very please with this and cannot believe GM didn't have the engineers to figure something like this out. Hats off to OTTP. Thank you for making a good product for an affordable price.
Old 03-28-2009 | 03:09 AM
  #278
08SStc's Avatar
hey OTTP, any more updates on the next set shipments? i understand you guys are busy, but the weather is to nice right now to hotrod around and have to worry about wheel hop
Old 03-28-2009 | 07:42 AM
  #279
Josh@ottp's Avatar
Originally Posted by INFE
Im still waiting for mine OTT any idea when i should be getting my mounts??
Pm me your name and I'll tell you how many people are infront of you.
What stage do you have and whats your tire pressure at?
Thanks for the kind words!
I have more alot mounts due in any day, I'm thinking tuesday but it depends upon customs. As always as soon as they come in I will ship them.
Old 03-28-2009 | 08:15 AM
  #280
scott allen's Avatar
Wow your up early.
Old 03-28-2009 | 08:32 AM
  #281
Josh@ottp's Avatar
Originally Posted by scott allen
Wow your up early.
I normally am. I was up at 5 am this morning..... I had a family members car to work on in the 20 degree weather
Old 03-28-2009 | 08:53 AM
  #282
Lucky you. Thats sounds like fun
Old 03-28-2009 | 12:00 PM
  #283
SloBaLt RiDeR's Avatar
any updates?
Old 03-28-2009 | 01:03 PM
  #284
Bl4des's Avatar
i have the stage 2 mounts and i have goodyear eagle gt tires and they are at 45 psi
Old 03-28-2009 | 02:08 PM
  #285
spike's Avatar
wowzer 45psi
Old 03-28-2009 | 02:15 PM
  #286
Bl4des's Avatar
it says to put 50 lbs in on the tire
Old 03-28-2009 | 06:15 PM
  #287
Josh@ottp's Avatar
50psi is the max pressure.... set them at 32-34psi and you won't have any more hop.
Old 03-28-2009 | 06:25 PM
  #288
Bl4des's Avatar
are you saying 32-34 psi for daily driving or just at the track
Old 03-28-2009 | 06:30 PM
  #289
schamsy's Avatar
32 psi is a standard number for tire pressure on almost all tires. Yes daily driving.
Old 03-28-2009 | 06:31 PM
  #290
Josh@ottp's Avatar
Daily driving and thats what most manufacturers recommend. Track would be 22-24 for a good place to start.
Old 03-28-2009 | 06:32 PM
  #291
Bl4des's Avatar
ok ill try it tomorrow
Old 03-28-2009 | 06:45 PM
  #292
BigBrother's Avatar
PLEASE specify that by "track" at 22-24 psi you mean "drag strip". Someone hits a roadcourse at those pressures and bad things could happen...
Old 03-28-2009 | 07:10 PM
  #293
schamsy's Avatar
Thanks captain obvious, were talking about accelerating from a dead stop so that is referencing a "drag stripe" situation. BE REAL!
Old 03-28-2009 | 07:14 PM
  #294
BigBrother's Avatar
Apparently you don't roadcourse or autocross much, where accelerating from a low speed corner exit can be an issue with a heavy foot.
Old 03-28-2009 | 07:33 PM
  #295
Josh@ottp's Avatar
I don't road race ever. But yes you are correct I should have been more clear.
Old 03-28-2009 | 07:34 PM
  #296
schamsy's Avatar
Forget it man.. I don't autocross, But I can hardly believe your car or 95% of the cobalts on here have enough power to blow the tires loose in second gear from a roll, where wheel hop could occur.
Old 03-28-2009 | 08:43 PM
  #297
Eagle_f90's Avatar
Here is one for you captian obvious when starting an auto-x your starting from a dead stop just like at the drag.
@Fast are you saying that with around 40 PSI and these mounts we will still hop? (I run 40 psi when I auto-x)
Old 03-29-2009 | 06:14 AM
  #298
Josh@ottp's Avatar
@40 psi if you drop the clutch you will get some axle tramp. slightly different then hop.
Old 03-29-2009 | 11:32 AM
  #299
Eagle_f90's Avatar
Got anything to fix the axle tramp too? Never heard of it so I always thought it was hop, I usaly dump around 3k to launch for auto-x.
Old 03-29-2009 | 08:03 PM
  #300
N8s07SS's Avatar
What exactly is the difference between axle tramp. & wheel hop? Can they both have damaging effects to your engine/drivetrain? Because even after installing these mounts and putting my summer tires on, I still have some sort of hopping going on and my car is basically stock (drop in K&N filter). Oh, and I was able to get the mount in correctly btw, and everything seems to be ship shape.
On a side note, I noticed some oil residue on the underside of the tranny when I was installing these (It didn't look like trans. fluid, but did appear to be coming from the tranny). I think I already know the answer, but is that normal? Has anyone else noticed this? You can see it in the pics I posted a few posts back.
Quick Reply: Billet Rotated Mounts
