Over The Top Performance Over The Top Performance is a supporting vendor.
Contacts: fast98 ; lsjwannabe
Billet Rotated Mounts
Old 03-29-2009 | 09:56 PM
  #301
RooTBeeR's Avatar
Originally Posted by N8s07SS
What exactly is the difference between axle tramp. & wheel hop? Can they both have damaging effects to your engine/drivetrain? Because even after installing these mounts and putting my summer tires on, I still have some sort of hopping going on and my car is basically stock (drop in K&N filter). Oh, and I was able to get the mount in correctly btw, and everything seems to be ship shape.
On a side note, I noticed some oil residue on the underside of the tranny when I was installing these (It didn't look like trans. fluid, but did appear to be coming from the tranny). I think I already know the answer, but is that normal? Has anyone else noticed this? You can see it in the pics I posted a few posts back.
trans fluid on a manual trans is just gear oil not lik atf fluid(usually red)
Old 03-30-2009 | 06:29 AM
  #302
boosted4dr's Avatar
Originally Posted by Bl4des
ok ill try it tomorrow
Typically follow your CARs recommended air pressure setting, not the tires. Tires have various different air pressure settings based on load bearing ranges.
32-33 should be ideal.
Old 03-30-2009 | 04:48 PM
  #303
N8s07SS's Avatar
So I don't need to be worried that I cracked my transfer case or anything?
Old 03-30-2009 | 10:07 PM
  #304
donjuaniii's Avatar
GeneraL QUESTION - Are these mounts designed to work better with stock height cars or lowered ones...? Or is there no difference?
Old 03-31-2009 | 02:06 AM
  #305
RooTBeeR's Avatar
well id say someting is leaking, either you engine, or your tranny if there is oil on it
Old 03-31-2009 | 02:27 AM
  #306
ls1fbody's Avatar
Haz l33t wheelz.
your mom is leaking.
both, doesn't matter. It does help with lowered cars in some ways i think, I could be wrong though.
Old 03-31-2009 | 02:37 AM
  #307
RooTBeeR's Avatar
FK YOU! buddy lol u can install yo **** yo self then! foo! haha
Old 03-31-2009 | 02:41 AM
  #308
ls1fbody's Avatar
Haz l33t wheelz.
haha, ok andrew, get ready man. I am hoping to have the pallet delivered on the 12th, so if it shows up early, we'll have some work to do!!
lol, sorry for the threadjack.
Old 03-31-2009 | 09:36 PM
  #309
qwikredline's Avatar
tramp is lite flex at the tire sidewall, i would suggest dropping tire pressure say 26 if you get a lot of it. I dont and i currerntly have pirellis on which are the worst for hop/tramp it seems and i had 32 psi dropped it and i dont notice it ata ll. check your suspensions bushings as well and are your shocks good. all these things affect it, but hop you dont ahve any more or youwould be screaming: hop is violent and if you drive through it you will break something. Does this help?
Most trans leaks if the trans is ok itself, is overfill of oil takes 1.9 us quarts as i recall...pm me for more info if you are stuck...
april or may? 12th?
Old 04-01-2009 | 12:43 AM
  #310
ls1fbody's Avatar
Haz l33t wheelz.
april my good man. APRIL. If that's possible, if not, then the closest to that you can get would be awesome.
Old 04-01-2009 | 12:50 AM
  #311
steddy2112's Avatar
:shifty:
Old 04-01-2009 | 01:34 PM
  #312
ls1fbody's Avatar
Haz l33t wheelz.
shifty right back at you, you sneaky bugger.
Old 04-01-2009 | 03:06 PM
  #313
VeNoM0713's Avatar
Hey fast98, any updates on these? i know they were supposed to be shipped out this week but i dont know when. thanks
Old 04-01-2009 | 05:32 PM
  #314
Josh@ottp's Avatar
I just got the rest of the mounts in today. Spacers are due in tomorrow for them and then they can ship out!
Old 04-01-2009 | 05:41 PM
  #315
SloBaLt RiDeR's Avatar
awesome, i hope im on this shippment.
Old 04-01-2009 | 05:48 PM
  #316
Josh@ottp's Avatar
As far as I know these will cover all pending orders
Old 04-01-2009 | 06:03 PM
  #317
VeNoM0713's Avatar
you dont get them justin.. sorry man. im getting your set also! thanks for the free mounts man!
Old 04-01-2009 | 06:24 PM
  #318
lol il kill u.
i will dissemble your car and u can play Easter egg hunt around western new york.. how about them apples?
Last edited by SloBaLt RiDeR; 04-01-2009 at 06:24 PM. Reason: Automerged Doublepost
Old 04-01-2009 | 06:33 PM
  #319
BigBrother's Avatar
LOL @ car parts Easter Egg hunt
In other news, i got my "old" set today from another member, absolutely CANNOT wait to get them in! And I just KNOW that OTTP is shipping my Koni's and Hawk pads as i type this, too...
Old 04-01-2009 | 06:37 PM
  #320
lol and if there not? i say we go to there shop and dissemble it and put it all over the united states. mmuahaha
Old 04-01-2009 | 06:48 PM
  #321
INFE's Avatar
nice i cant wait
Old 04-02-2009 | 03:22 AM
  #322
BigBrother's Avatar
WHEELSPIN!! GLOOOOOORRRIIOOUUSS WHEELSPIN!!!!!!!
I cannot possibly explain the difference these mounts make! It's like completely different car!! Guys who are waiting - you only THINK you're excited - you don't even know how excited to be - the car can actually be DRIVEN now... OMG... It's ******* WONDERFUL... Okay, calm down, try to make a nice, objective post... Not going to be easy...
Okay - vibes. Worse than expected, but nowhere near as bad as poly mounts - like, replace one mount with poly and it'd be about this bad or slightly worse. Only annoying thing - and it's a minor gripe - with poly, once you're over a certain RPM, the vibes disappear; with these the vibes are lesser than with poly, but they make themselves known across the revs. Kinda like putting a louder muffler in, but without the loud part, lol.
Josh and Qwik and company - I did not have torque specs. I tightened all of the 18mm to what is probably about 80 lbs give or take, both the 5 tranny bolts and the 2 mounting bolts. Will getting those to whatever they're supposed to be at reduce the vibes? The 3 15mm on the rear I ade as tight as I possibly could with a slightly undersized ratchet; so they're probably at about 80 lbs as well.
Install is easy of you can get the car up. Laying on your back, it's not as simple as one would wish. This is not because of OTTP's design, but GM's. A few notes:
GET A RATCHETING 18mm BOX END WRENCH OR HATE YOUR LIFE. Might be different on the 'balts, I dunno, but in a RL, the upper tranny bolt WILL NOT clear the airbox with ANY kind of socket on it. The box-end makes a few others simpler as well, though it's not necessary.
The foil-wrapped cables above the rear mount - I think they're shifter cables, not 100% sure - will contact the raised rear mount. Not BADLY, but it will contact, and it will make getting that thing in harder then it could be 'cuz it wants to push the mount down and forward while you're trying to torque the rearmost 15mm long bolt.
Take the rear tranny bracket off. You will want to try to get the mount in without doing so, don't. Unclip the sensor thingies and drop the bracket, this will save you mucho effort trying to get the spacer rings in.
Put the car on stands and use your jack to raise the tranny. Seems obvious, but I bet somebody was going to leave the car on the jack and try something else. Don't.
That's about it.
Back to OTTP - guys, if the spacer - or the bottom of the new mounts if there isn't one anymore - could have a locking key thingy like the bottom of the stock mount does, it would be 300 times easier to get all that aligned and in. Just a thought.
And now, back to driving with them...
Some vibes. Annoying at a stoplight. Until it turns green, and you realize that whether you want to go fast or not, what you DON'T have to do is concentrate on getting off the line smoothly for fear of the dreaded hop. It jst changes the way you THINK about driving, not to mention the way you actually drive. I no **** believe that these mounts - with ZERO other mods - could drop 1 or 2 tenths off your 1/4 mile on an otherwise stock car. You just have som much more confidence off the line, and it's so much easier to launch.
Way to go OTTP. Too bad GM decided to release a "don't fix the axles under warranty that our design flaw broke in the first place" TSB; all they needed was to release a new motor mount and the issue would be solved. Sad, really. One more time - awesome job guys, thanks for making me fall in love with my car all over again.
Old 04-02-2009 | 03:24 AM
  #323
BigBrother's Avatar
Slow server = accidental double post.
Did I mention that these mounts will change your life? They help you make more money, they make your ***** 30% larger, and they cure cancer. And AIDS. They improve the economy and stop global warming, too. Seriously, they do.
Old 04-02-2009 | 07:18 AM
  #324
shutzero's Avatar
glad they worked out for you!
Old 04-02-2009 | 10:57 AM
  #325
Josh@ottp's Avatar
That's about it.
The main thing you missed it that you need to loosen all of your mounts, even the top two and let the engine settle. This will get rid of half of your vibes.
Quick Reply: Billet Rotated Mounts
