Billet Rotated Mounts
#351
were these able to get shipped today???
#355
No I didn't mean that. Sorry, in that sentence above, it should say this to be more clear:
I should specify that is for ONLY the 2 through bolts on the lower mounts, and ALL 6 bolts (3 per mount) on the 2 upper mounts that thread into the engine/trans.
The specs I posted are for only the bolts that are either A. Going through the rubber portion of the mount or B. thread into the engine/tranny block. Any bolts that don't fit either of those descriptions have different torque specs (which is probably why people are getting confused, hence why I posted the images from the build book). I think if you look in Area47's thread about these mounts, the torque specs for the other bolts can be found in there. I know this all sounds sort of confusing, but if you just look at the images I posted above, I think it's pretty clear what I'm talking about.
Front Transaxle Mount to Transaxle Bolts (2 bolts) - 66 ft/lbs (MUST BE TORQUED IN SEQUENCE BELOW)
-----> Top bolt, then bottom.
Rear Transaxle Mount to Subframe Bolts (3 bolts) - 44 ft/lbs
#356
#361
#363
#365
#372
Guys just a question I got the stage 2 mounts and they don't come with the rear mount spacer right. Because on OTTP's websight says that stage2 still uses that spacer. Please tail me that the billit mount is all that is needed in rear.
#373
The rear billet mount has the spacer built into it so you don't need it.
