Over The Top Performance Over The Top Performance is a supporting vendor.
Contacts: fast98 ; lsjwannabe
Billet Rotated Mounts
Old 04-12-2009 | 10:01 AM
  #376
scott allen's Avatar
Why didnt they just machine the mounts so you would not need the spacers?
Originally Posted by lsjwannabe
Two for the front two for the rear
I dont understand is there a pic? I now know you dont use the spacers in the rear mount,i need pics of front mount or a drawing.
Old 04-12-2009 | 10:22 AM
  #377
stealthy1ss's Avatar
The spacers go on each side of the rubber part if that helps you. Same thing for the rear mount.
Old 04-12-2009 | 10:25 AM
  #378
read post 373 they say not to use them in the rear mount. Thats why i dont understand why we would need 4 spacers in one mount.Im settint here lookingat the mount and just dont understand.
Old 04-12-2009 | 10:42 AM
  #379
mantiskungfu's Avatar
in post 373 he is talking about the spacer on the bottom, not on the sides.
Old 04-12-2009 | 10:48 AM
  #380
so the spacers go were the long bolts go . The way i see it is the front mount the 2 spacers go were it bolts to the tranny ,right?and the back mount the spacers go on each side were the long bolt goes ,Right.
Old 04-12-2009 | 10:49 AM
  #381
lsjwannabe's Avatar
He was talking about a rear spacer that used to be used with the older designed mounts not the billet mounts. We added the spacer into the design.
Old 04-12-2009 | 10:53 AM
  #382
ok so all 4 spacers i use in the front mount? 2 on the tranny and 1 on each side of the long bolt?
Old 04-12-2009 | 11:54 AM
  #383
08SStc's Avatar
im still awaiting my order, these stage II mounts plus the SCA bushings, can i get some sort of update on that?
  #384
lsjwannabe's Avatar
What was the order number?
Old 04-12-2009 | 11:57 AM
  #385
08SStc's Avatar
i dont have an order number for the mounts cuz i went throught fast98 for them but the SCA bushing order number was 782. and i was told they would be shipped together
Old 04-12-2009 | 11:58 AM
  #386
BLAZIN07SS's Avatar
I'm too JDM for you
dude are you serious? how can you not understand that 2 go on the front mount and 2 on the rear mount. they are talking about the spacer that was previously used on the old design that went on top of the mount, that spacer is now incorporated into the design. put one on each side of the mounts
Old 04-12-2009 | 11:59 AM
  #387
lsjwannabe's Avatar
What exactly do you mean? Mind shooting me a pm with all the details?
  #388
INFE's Avatar
Hey OTT i was wondering if you could give me a update on the stage 2 mounts i ordered my order # is 715
Old 04-12-2009 | 12:03 PM
  #389
lsjwannabe's Avatar
I do believe yours are set to be shipped on monday iirc. We were just waiting on spacers then we had to machine them. That is all done now though
Old 04-12-2009 | 12:11 PM
  #390
08SStc's Avatar
PM sent
  #391
twzted's Avatar
Where are mine?
I want them hand delivered by Josh or Sean!
Old 04-12-2009 | 12:15 PM
  #392
INFE's Avatar
sweet
Old 04-12-2009 | 12:16 PM
  #393
lsjwannabe's Avatar
Originally Posted by twzted
Where are mine?
We charge extra for that
Old 04-12-2009 | 12:58 PM
  #394
SloBaLt RiDeR's Avatar
ok? im curious where mine are, i sent u guys a bunch of pm's and i havent gotten a response.
order number 664
i ordered on the 10th of march
MOUNTS AND WIRING HARNESS
i got everything else i ordered
Old 04-12-2009 | 01:45 PM
  #395
desperado's Avatar
Thanks lsjwannabe for the reply that was what i needed to knw. installed them yesterday, that rear mount was a little difficult to get the trans bracket bolts in so i losened the upper passenge motor mount and got it to rotate a little more, but when i tightened those 3 motor mount bolts to 74ft/lbs the center bolt snaped so I was not going to test drive it like that. just have to wait until I replace it. A good torque spec sheet along with a instructions would have been nice. Ottp makes a great product thought, can't wait to drive it.
Old 04-12-2009 | 01:51 PM
  #396
Can you post instructions ,please josh,thanks.This is the way i want to do it the rear mount 1 spacer on each side of the long bolt.And the front mount 1 on each side of the long bolt.Is that right?
Old 04-12-2009 | 02:06 PM
  #397
desperado's Avatar
Yes man the cylindrical spacers go 1 per side of each mount "Spacer-mount-spacer" but the real instruction should include mounting sequence and torgue specs and any other misc..
Old 04-12-2009 | 02:22 PM
  #398
ok thanks man.
Old 04-12-2009 | 04:10 PM
  #399
BigBrother's Avatar
How'd you snap a bolt at 74 lbs?! Before that number was out - that's correct torque BTW - I overtorqued mine significantly, and nothing broke... I can't fathom snapping any kind of bolt with little torque, lol. Wood should be able to take 74 lbs, LMAO.
Old 04-12-2009 | 05:02 PM
  #400
desperado's Avatar
dude it preplaxed me to, 74 isn't much but the bolt i think is a 10mm wheres the through bolts on the trans mounts are 12mm which should easily take that torque. The 10mm on the other hand i was ife about.
Quick Reply: Billet Rotated Mounts
