Over The Top Performance Over The Top Performance is a supporting vendor.
Contacts: fast98 ; lsjwannabe
time attack big brake kit review
Old 11-10-2009 | 09:46 PM
Omnigear's Avatar
got my packaged today, happy as two hogs.
started removing the old parts all went well.
now the nightmare starts
first the modified mount.
the thread is for a fine thread
the stock bolt is course so i went
to get the right thread, now the bolt
i got was to long on the bottom part
so i have to cut it.
got that all resolved , i start putting
the brake lines check if it was long enuff
by turning it all the way left and right.
w00t the lines is a tad bit short it
strains on all the way right. its just
enuff to have tension, it still goes all
the way to the right but tension on the brake
lines when turned all the way.
so far thats all that have gone pass.
tomm i will finish the other side.
i hope the bottom bolt dont come off.
because the only reason i know it was
bottoming out is the moddified plate
and the caliper bracket splits a part.
so i cut it down till it was not doing
it.
Update:
day two
the only problem i had was the brake line this time around since i cut the bolt already along with the other side yesterday.
the metal brake line and the supplied brake line is of a different thread, how do i know this because i tried to put the
supplied brake line and the thread would not match up and i was feeling the thread was about to be cross or it will pop
out.
another thing i check is if i can put the stock line to make sure that i did not mess up the thread on the metal line.
it goes right in no problem. So tomm i have to get brake lines made since it was a late night and the flash light we have
was not giving enuff lumination to see the threads are messed up. besides that everything is in , i just need to bleed the brakes
after installing the lines.
Old 11-10-2009 | 09:48 PM
_UnLiMiTeD_'s Avatar
wow... why didnt you just return it....
Old 11-10-2009 | 09:56 PM
Omnigear's Avatar
minor things
its not like the
rotors or mount
are mangled
Old 11-10-2009 | 11:07 PM
Area47's Avatar
Rent me! per hour
buy shorter bolts for the bottom bracket. notch the caliper bracket in that small area only. IE drill bit a tad bit larger that bolt.
Old 11-10-2009 | 11:10 PM
1badBlueberrySC's Avatar
QFT! He just did the swap not too long ago!
Old 11-11-2009 | 11:31 AM
Omnigear's Avatar
it would be nice if the parts and extra work was done already.
or was disclosed. i thought it was plug and play,
not gripping about it mearly stating what i experience
while installing it.
Old 11-11-2009 | 12:20 PM
06blackg85ss's Avatar
nothing is plug and play my friend
pretty sure it's listed you need longer brake lines (I am piecing the setup together myself).
other than that, a little modification ain't bad.
Try installing the vulcan long tube turbo mani lol. 13.5 hour job right there.
Old 11-11-2009 | 12:27 PM
ls1fbody's Avatar
Haz l33t wheelz.
After 6 months of research and development, my brake/suspension kit wasn't quite bolt on either. That's what happens when you go semi-custom. The end result is where the true value lies however.
I'll be looking forward to seeing all your guy's car when i get home for sure.
Old 11-11-2009 | 12:40 PM
Omnigear's Avatar
the brake lines was included with the kit.
Old 11-11-2009 | 12:45 PM
06_SIC_SS's Avatar
my WIlwoods are fun to fit lol i need to custom fab a bracket to fit em
Old 11-11-2009 | 10:22 PM
Omnigear's Avatar
updated
Old 11-11-2009 | 10:24 PM
slowswap's Avatar
This does not sound very good.
Old 11-11-2009 | 11:24 PM
Omnigear's Avatar
ill prolly call josh tomm and talk to him about this.
everytime i work on the car its after workin hrs
so its4-6pm -8 gmt
Old 11-12-2009 | 12:08 AM
Area47's Avatar
Rent me! per hour
the lines i used were 2 inches longer from ftp. not sure what they sent with the kit.
Old 11-12-2009 | 12:26 AM
spike's Avatar
saved for install saturday
Old 11-12-2009 | 02:02 PM
Josh@ottp's Avatar
Guys, I just found out the kits went out without the mounting bolts. The correct size is 12mmx1.25 in a 30mm length. As for the brake lines they are 2 inchs longer than stock and have fit other cars, once we get them back we will compare them and find the root cause of his problem.
Old 11-12-2009 | 05:43 PM
Omnigear's Avatar
final update
got the car running
the brake line i got
would not let the fitting
go all the way in. hence it was
not catching th thread. the place
bonacos explained it to me but
i have forgotten it. so i got the
new lines in front and back, they
went in like butter.
i still have the stock pads in the front
when i get the hawk hps i will test the brakes
out and check the bolts and lines.
Old 11-16-2009 | 12:24 PM
Omnigear's Avatar
ill try sending the core and the lines after i get out of class
havnt gotten a chance 2 run 2 post office.
Old 11-16-2009 | 12:37 PM
hungryhip-ccp's Avatar
hmmm
Old 11-16-2009 | 12:45 PM
ikeryder13's Avatar
How much was the kit, what size caliper?
Old 11-16-2009 | 02:16 PM
Omnigear's Avatar
750? +150 for core which you get back when you send it back.
you are using the stock caliper your just changing the geometry
by having bigger rotors and moving the caliper out more.
Old 11-16-2009 | 02:18 PM
ikeryder13's Avatar
is that safe? is the caliper still covering enough of the rotor to stop efficiently?
Old 11-16-2009 | 02:49 PM
Omnigear's Avatar
i hope so ^_^
i dont think
this mod is dot approved =p
well beside my brake lines.
Old 11-16-2009 | 02:51 PM
ikeryder13's Avatar
LOL well just make sure that u wear a helmet LOL
Old 11-16-2009 | 02:52 PM
Omnigear's Avatar
so far so good
Quick Reply: time attack big brake kit review
