For Sale CX Racing Front Mount Heat Exchanger
SOLD
Need this gone. ASAP
CXRacing(small) FMHE $180 Shipped OBO
It comes with hoses, clamps, mounting brackets+hardware Ran it on my car for 30-35k miles with no problems. It's in "Like New" condition, including the fins(i had the lower grille insert and aluminum window screen keeping all large harmful debris out/away from it).
INSTALL
All you need to do is drill two little wholes(1/4" iirc) in the crash beam to run the bolts through and then run the hoses.
Short hose goes from the drivers side of the stock h/e to the top of the cxr.
The longer hose goes from the bottom of the cxr to the pump inlet.
Add fluid and bleed the air out of the system.
This one is similar to this one
http://www.cxracing.com/mm5/merchant...Category_Code=
its already all packaged up and the box i have it in(well wrapped) is 29-1/4"(Wide) x 9-1/4"(Tall) x 5"(Thick) so the h/e itself probably has a core of 2.5-3"(thick) x 6-7"(tall) x 20-24"(wide)...wish i had measured it before i boxed it up the whole box only weighs about 10lbs also
PayPal Only.
Thank's For Looking!
INSTALL
PayPal Only.
no, similar though. that one has an inlet/outlet at each end of it(one on each tank) mine has them both on the drivers side of it. its a different size too, cant remember if its bigger or smaller though. mine is about 3 years old, i dont know if they still make this exact one
thanks!
thanks!
not like I'm on here yelling and **** saying he's overpricing when he is not like other for sale threads.
this is the closest one i could find
cxracing.com: Aluminum Heat Exchanger For Air to Water Intercooler Applications, Core: 21"x6"x2.5"
but like i said, i cant remember the core size of it. the box i fit it into iirc(its in cali at my parents still) 29" long...ill get the other 2 dimensions later when i hav have someone measure it for me
n20saturn
09-30-2015 12:26 AM
