For Sale Dynotune EFI nitrous kit
Brand new Dynotune EFI nitrous kit. decided to go a different route.
Never installed this kit, or filled the bottle. decided to go a different route and dont need this anymore
Paid 410 to get this to my doorstep. asking for 350shipped
This System will work on 4 or 6 cylinder engines. The system is adjustable from 35 to 75 HP. It can go up to 150hp with diffrent jets.
The following parts are included:
>10lb bottle with high flow valve
>4AN stainless bottle nut & Teflon washer
>Stainless quick connect Bottle brackets and hardware
>16 foot braided stainless feed line, blue fittings
>High Flow Nitrous and Fuel solenoids
>Solenoid mounting bracket
>2 foot Braided stainless Nitrous and Fuel feed lines, red and blue fittings
>Braided stainless line for Fuel rail test port installation, red fitting
>Jets for 35, 50 and 75HP (max 175hp with diffrent jets)
>High flow Wet Nozzle
>Wet Nozzle Mounting adaptor so the Nozzle does not blow out during injection causing a fire, makes mounting the nozzle in plastic or rubber a snap!
>Nozzle tap
>5/16" fuel injection hose with clamps and brass "T", all fittings and clamps for a complete installation
>Lighted arming switch, relay, wire and wire harness, fuse, crimp terminals etc..
>Micro throttle activation switch and mounting bracket
Box is in the trunk of my rental car (my car was rear ended and is in the shop until the end of december)
Will post pics tomorrow when i get up
>Nozzle tap
09-28-2015 12:51 PM
