F/S: SCM Cobalt Heat Exchanger
its bigger than the fluidlyne heat exchanger for the cobra and made to fit in out front mount. i do believe its a good alternate than spending more for a dual pass that allows for a surge tank for more coolant. you can either run this separate or with the stock heat exchanger. pump-stock-scm-manifold. youll be able to carry a lot more fluid than in this compared to running with the stock cobra, and i must say it looks a lot nicer sitting in the front bumber
#36
Still trying to become a supporting vendor, no luck as of yet on any replies.
I've put up the rest of my current stock on ebay, they are going for a little less under retail.
1 more left, but this is the last production run until the price goes up a little.
#40
#41
i would recommend runnign both though, make the line goes through the stock first after the pump to absorb the first blow of the heat, then once it passes through this unit it will be perrrfect
#43
i got a question... if someone has 2 heat exchangers (stock and one like this) is the stock pump going to be dependable to run 2 of these. i was thinking of getting another heat exhanger but don't know if i should have 2 or just run a bigger one in the stock location.
#44
the stock pump will be fine, your only sunning about another quart of cooling fluid and water, the viscousity isnt thick at all there wouldnt be any problem, just instead of the tube running after to the mainfold, it just lets another helping of air let it cool down as it continues to flow back to the manifold
i jsut like the idea knowing im safe running both with my 2.6, thats just me. it would still be fine either or and really no question asked if your bigger than 2.6 pullied
#47
#48
the dual pass allows for holding mroe fluid in your system by adding another surge tank, you can allows add it if you want it wouldnt hurt but youll pretty much put out the same temp with another good heat exchanger such as this to having the dual pass
#49
So in other words, this thing will work just fine by itself.
